First post, by CursedSilicon
Hi all, long time lurker, relatively new poster, etc
I've got a large collection of Sun Microsystems machines from around the turn of the millennium (Netras, a SunFire 420 and others)
The machines all still have their original SCSI based drives, albeit in unknown condition. However given the machines are nearly 25~ years old and mechanical hard drives are, well, mechanical. It would be nice to replace them with something more reliable
StarTech make a SATA to IDE adapter that works wonders in machines that can take IDE (and unlike the cheap clones, actually seems to handle DMA modes properly, not just PIO!)
Over in the early Macintosh world there's a plethora of SCSI emulator devices (Raspberry SCSI, BlueSCSI etc) however these are significantly lower speed SCSI devices. Capping out at about 10MB/s from what I've been able to find online. Plenty fast for an original Macintosh from 1984 of course!
The Suns I have all appear to handle either "SCSI Ultra160" or "Ultra320" (for 160 and 320MB/s respectively) which also comes with its own "similar but different" connector
Is there anything out there for adapting modern SATA to SCSI Ultra interfaces? As I understand it the two are "reasonably" similar (though not identical) protocols.
As an aside I also purchased a https://firmtek.stores.turbify.net/sata1ve2plus2.html 64-bit PCI-X to SATA II expansion card for future testing
This device is the only one seemingly in existence (or at least, still in *production*) that sports OpenFirmware rather than a PC BIOS Option ROM. This allows it to operate as an (extremely quick!) boot drive for older Macintoshes, even under MacOS 9.2. Due to its use of OpenFirmware, it may also be compatible with Sun machines as well as other vendors that implemented OpenFirmware. However adapting the devices SCSI cages to SATA would be a rather destructive process, and limit me to only 2 (or 4) drives at maximum.
Reply 1 of 19, by Disruptor
Be careful with the wording.
You surely don't mean "Ultra" but LVD, which is "Ultra2" and above.
There does exist classic Single-Ended (SE) SCSI, which basically comes in narrow (N in Seagate wording) and wide (W) flavour and in asynchronous speed, synchronous speed, fast speed (F) and ultra speed (U). UW SE SCSI supports up to 40 MB/s.
There also exists low voltage differential (LVD) SCSI, which basically is wide only and in Ultra2, U160 and U320 speed. U2W LVD SCSI is 80 MB/s.
I have adapters from ACard, which are Ultra-Wide (UW), means Single-Ended (SE) and a firmware upgrade to raise the limit to 2 TB disks - they get close to the 40 MB/s, but are likely for above 200 €/$.
I don't have LVD adapters.
For internal devices there are basically 3 types of connectors: Narrow (50 pin), Wide (68 pin) and SCA (80 pin).
Reply 2 of 19, by luckybob
Adapters exist that let you put sata drives on SCSI. case in point: http://www.acard.com/index.files/Page385.htm
Several years ago, they were in the realm of affordable. Then suddenly something happened and ebay prices went from affordable to "nucking futs". Why? I presume someone realized if they bought the last 2-3 boxes, they could re-sell them at 10x the cost.
If you have the option to NOT use SCSI. that is going to be the cheapest option. I like the idea of add-on sata cards.
U160/U320 drives are still somewhat affordable and working drives are easy to come across. that will not last much longer.
Reply 3 of 19, by weedeewee
Or go for the IDE cdrom to SCSI acard adapter, firmware mod it and use a SATA to IDE converter on it together with a SATA SSD 😁
Here's some reading about that https://68kmla.org/bb/index.php?threads/conve … aec-7726.38935/
edit: CF card is also possible.
Do not ask Why !
Reply 4 of 19, by CursedSilicon
Going SCSI -> IDE -> SATA sounds like a a recipe for madness. But it's still a heck of a lot cheaper than those $200 adapters mentioned. I'll have to pick one up and tinker with it
Reply 5 of 19, by luckybob
K.I.S.S.
Keep it simple, stupid. SCSI notoriously doesn't play nice with adapters. Double so with cheap adapters.
This is coming from someone with a literal bookshelf stacked with hard drives, and an entire shelf dedicated to SCSI. If a sata card is an option, it's going to be the cheapest and easiest way. Of you really want to dive into the deep end, it can be fun, but expensive.
Reply 6 of 19, by weedeewee
CursedSilicon wrote on 2024-04-17, 19:05:
Like most things, It works best if you know what you're doing. One catch though, going narrow requires high byte termination on the acard. there's an EEVBLOG forumpost about that.
and you don't have to go SATA, IDE-CF adapter also works and those tend to all be passive, ie 40 pin IDE connector to CF connector.
Have fun.
Do not ask Why !
Reply 7 of 19, by megatron-uk
This is one of the reasons I don't have my older Unix workstations out and used very often: SCSI drives are loud.
You have the various (slow) SCSI emulators for 5 and 10mb/sec scsi1/2 (depending on if they are sync/async) but above that (eg even for basic wide SCSI) the prices get insane.
Putting an SGI Octane on a 5mb/sec emulated SCSI drive didn't sound like fun.
I'd love a simple scsi to ide converter to plug in cf cards or even pata laptop drives in to these older systems, but the old acard adapters are insanely expensive and very much hit and miss in their capabilities - I went though about three variants of acard adapters trying to get a big IDE drive working on the fast SCSI 2 interface of an Amiga accelerator about 10 years ago. It was far too expensive and difficult in the end and I gave up.
https://www.target-earth.net
Reply 8 of 19, by dionb
megatron-uk wrote on 2024-04-18, 07:17:
Not all of them.
In particular the 9-18GB Seagate Cheetahs and 18-36GB Quantum Atlas IV are about as quiet as mechanical HDDs can get. The 1.7GB unbalanced jet engine emulator in my Sparcstation 20 died and I replaced it with a Cheetah 10k 9.1GB. Not only is the system vastly more responsive, but it's quiet too, with a pleasant hum as opposed to the previous scream. I have an Atlas IV in my dual P3 system and it is equally fast & quiet.
So it might be worth shopping around. I've been fortunate in recently coming into a pile of those Atlas drives, so should be good for quite some time yet.
Nonetheless, there's definitely value in the idea of a community-designed solid state device or adapter to something contemporary like that.
Reply 9 of 19, by megatron-uk
dionb wrote on 2024-04-18, 07:53:
Not all of them. […]
Not all of them.
I guess I am just now attuned to the (lack of) noise from 2.5" drives and solid state. I spent a large portion of the early part of my career with SS 5's and then Ultra 1's and the occasional SGI Indigo 2 on my desk.... and I have no desire to replicate the noise of those drives. I did buy an Aztecmonster SCSI/CF adapter a good few years ago to use as storage on a VME backplane based NetBSD system running a 68060, but the price of those was simply crazy to do that everywhere else!
My Octane 2, Indigo 2 (and a Sun Blade 1500) all now reside in my garage workbench area and only get turned on when I am in there specifically to do something with them (which tends to be only spring-summer period!).
Reply 10 of 19, by dionb
megatron-uk wrote on 2024-04-18, 08:47:
Believe me, neither do I. The drives I mention are no noisier than a good 2.5" drive (and the frequency of the sound they do make is lower).
Reply 11 of 19, by weedeewee
I think I paid ~€30 for the acard ATAPI to SCSI adapter,
already had a TL866 eeprom programmer €100 & hot air gun €500 to desolder the eeprom
had to do some thinking on how to adjust the firmware file, hourly rate of ~€25 - €100
programmed the file to eeprom
attached it to scsi bus,
added an old IDE hard drive to acard adapter first, worked,
tested with CF2IDE adapter & 4GB CF card instead of IDE hard drive, worked,
tested with SD2IDE adapter, worked
tested with SATA2IDE adapter, worked,
max transfer I got was around 120MB/s,
I guess it's the SATA2IDE adapter max transfer speed.
even got it to work on a narrow scsi bus,
figuring out that it needed high byte termination to work
So yeah all in all it is not way too expensive,
the time and equipment needed for it,
it is just not too costly for the little enjoyment it brings,
probably cost me more than a personal months wages in all,
though I don't get payed during my personal hours.
While i'd like to test the real acard ATA-SCSI adapters or other IDE2SCSI adapters,
there is at present no incentive for me to pay the amount that is requested for those adapters,
those are just way too expensive for me at present.
Anyway, the link on 68kmla will give you some more info if you want to give playing around with the adapters another try.
Enjoy !
Do not ask Why !
Reply 12 of 19, by mdog69
Boot the Sun boxes over the network using NFS.
That way you can use your existing modern storage, and the lack of SCSI drives goes away.
Keep the size of the NFS shares realistic - I've found that with older versions of Solaris installing packages can fail with "insufficient space" caused by code that spits out it's dummy when faced with terabytes of free space.
I've managed to netboot Solaris 1.1.2, 2.3, 2.6 and 7 - for various reasons: mainly backup and restore of legacy kit (day job), and because I can (hobby). This has been with IPX, SS5, SS10, Ultra5/10. I've got an Netra240 that's waiting for similar treatment.
Reply 14 of 19, by luckybob
They ignored me. I tried like a month ago.
Reply 15 of 19, by BloodyCactus
for older systems older scsi2sd v5.2 or zuluscsi v6/rp2040. I avoid the ones that boot linux because you gotta do the whole load-up/shutdown mechnism so you dont corrupt the images.
Reply 16 of 19, by CursedSilicon
luckybob wrote on 2024-04-30, 16:01:
The trick I'm told is to send it from a business looking domain. If you're a corporation they're usually hungry for sales and happy to send out review units
Reply 17 of 19, by hybridtheory101
Hey so I have about 50 old enterprise level harddrives which appear to be the ultra320 SCSI connection which I'm not setup to perform data recovery from. What do I need to purchase to make this possible.I use disk drill on sata drives primarily?
Reply 18 of 19, by dionb
hybridtheory101 wrote on 2026-01-28, 23:52:
What kind of computer do you have? And which buses are in it?
Easiest and most reliable solution would be a PCIe SCSI adapter like the LSI LSI20320IE. You'd need a free PCIe 4x slot for it of course.
If that's not an option, the fun starts. As you can read above, adapters are expensive and finicky to the point of unreliability. There are (old) USB-SCSI adapters, but they're almost all narrow SCSI. You can get narrow-wide adapters and the U320 drives are backwards compatible so you could (in theory) get it working - slowly - but you then go down the rabbit hole of termination, as well as probably having fun finding drivers if they even exist for whatever OS you're using. Tbh, I'd sooner just grab an old P4 or similar and stick an Adaptec 29160 into it. Why the U160 instead of U320? Because that card gives you 50p narrrow SCSI as well, which you don't need now, but if you start doing SCSI you'll get something narrow sooner or later.
Reply 19 of 19, by eisapc
It may be easier to grab a cheap PC with PCI and stuff in an U320 Adaptec. You may need a SCA adapter to connect the drives. Enterprise drives usually connect to a SCA backplane.
Just copy over the file to any SATA drive connected to the internal ports or to a network share.
PCIe to SCSI Adapters seem to be as rare and costly as the USB to SCSI variant.
Other choise is to use a blueSCSI device in target mode to copy over the files straight to a SD card.
You just have to extract the disk image files or just mount them on a VM.
