Reply 400 of 1165, by PC@LIVE
- Oldbie
Here we are talking about "computer archaeology", contrary to what you might think, a PC XT can be quite complicated, first of all it is not easy to find the manual, which allows the correct settings of the jumpers (or switches), then there is the difficulty of finding suitable HW, although it is true that today there are cards for any, indispensable today, the 8-bit ISA cards with IDE 40 PIN controller, the floppy controller card would also be useful, however if you have an IDE-CF adapter, you can use a memory card of a few MB, they typically had 20 MB disks, So a 16 MB one could be usable, but certainly a 32 MB one, it allows more than enough space, for programs and Windows (version 1. X).
Another problem is the video card, the cards for those PCs were not VGA, maybe later it was used, on what I used around 1990, there was an EGA card, and it has a 9 PIN connector (15 for VGA), today I think it is almost impossible to find suitable monitors, I have some old cathode-ray tube monitors, but I'm pretty sure they don't have EGA type ports, only VGA except surprises, having an 8-bit ISA video card with EGA type port, but I think it's a Hercules (?), I should find an EGA to VGA adapter, that is, 9 Pin M to 15 pin F.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
