1997 period correct retro PC build
First post, by drone16
So I have this sweet beige box built, and just now decided to document what year the parts were made/sold. This is the result.
MB ECS P5TX-Bpro V2.0                   1997   https://theretroweb.com/motherboards/s/ecs-p5tx-bpro
CPU Pentium 166 1996 https://en.wikipedia.org/wiki/List_of_Intel_Pentium_processors
GPU 3dfx Voodoo 2 1998 https://en.wikipedia.org/wiki/Voodoo2
HDD FUJITSU MPB3043AT, 4.3 GB 1997
2D video Matrox Millenium II 8MB 1997 https://www.computer.org/publications/tech-news/chasing-pixels/matrox-mga
Network 3Com XL PCI 3C905-TX 1996 https://techinfodepot.shoutwiki.com/wiki/3Com_3C905-TX
Sound ESS ES688 MW-0203131 V1.0 1995 https://dosdays.co.uk/topics/Manufacturers/ess.php
CDROM LG CRD-8484B 2000 https://fccid.io/E-H021-00-2766
Mouse Microsoft IntelliMouse 68874 1996 https://fccid.io/C3KKZB1
Keyboard Honeywell 101WN63S-14E 1992 https://telcontar.net/KBK/Micro_Switch/WN
--------- previous MB and CPU --------
CPU AMD 5x86-P75-133 ADZ? 1996 https://en.wikipedia.org/wiki/Am5x86
Motherboard Lucky Star LS-486E REV:C1 1996? https://theretroweb.com/motherboards/s/lucky-star-ls-486e-rev-c1-rev-c2
I bleached the plastics using hydrogen peroxide the best I could 😀
Still trying to access the Win95 shared folder from my Mac to copy and install various drivers... [Solved, FileZilla FTP]
I had to solder custom PS/2 to DB9 Serial adapter for the mouse.
Suggestions? Likes? Errors? WTFs?
Reply 1 of 61, by dominusprog
Pentium 166 is a nice upgrade. Anyway, my suggestion for a 2D graphics card is S3 Trio64+/V2 or Cirrus Logic like CL-GD5434.
Reply 2 of 61, by drone16
dominusprog wrote on 2024-04-24, 12:23:
Why? If I may. What is wrong with Millenium II? I do have S3 Trio in my drawer, lol
Reply 3 of 61, by appiah4
drone16 wrote on 2024-04-24, 12:33:
Why? If I may. What is wrong with Millenium II? I do have S3 Trio in my drawer, 🤣
I suppose the poster above mentioned those two cards due to being more compatible with early DOS games. I personally don't think it is a big consideration for a Socket 7 system. The Millennium is a much better Windows/GUI accelerator, has a better DAC, has sharper VGA output and is AFACI compatible enough. I mean, you have a Voodoo 2 in the system I doubt it will be used for DOS 1980s DOS games..
Reply 4 of 61, by jheronimus
I mean, you'd already be out of your period because of the Voodoo card, so I'd pick at least a P166-MMX. It has more L1 cache, so just a bit faster, but more importantly — you might want to use setmul (SetMul - Multiplier control for VIA C3 / AMD K6+7+8 Mobile / Cyrix 5x86) to slow down the CPU for some speed-sensitive games. In other words, all benefits without any drawbacks.
Otherwise — I think this is more or less a standard Socket 7 build, you shouldn't have any problems with it.
I'd also recommend FTP for network transfers, should be easier to do. Maybe your router can share a USB disk over network, that would be enough.
MR BIOS catalog
Unicore catalog
Reply 5 of 61, by drone16
jheronimus wrote on 2024-04-24, 13:11:
I ordered Intel Pentium MMX 200MHz an hour before posting this 😀
With FTP, what FTP client I use on win95?
And should I use Win98 with P200 MMX or still Win95?
Reply 6 of 61, by Namrok
I have a probably less rigorously "correct" 1997 build. Went with a Pentium 233 MMX, as those were fairly common, especially towards the end of 1997 when the early Pentium II's were coming out and MMX chips were sliding into the "budget" category. For the video card I chose a Riva 128.
1997 is just a kind of shitty year for graphics cards. You get pretty rudimentary, low powered 3d accelerators with 4 MB of VRAM that really struggle to be playable on games that came out by even 1998 like Unreal or Half-Life. Even Quake 2 which was a 1997 game runs about 15-30 FPS on a Riva 128 or a Voodoo, unless aggressively tuned to remove a lot of the features that give Quake 2 it's distinctive look. They were really a backward looking batch of cards that strove to make 1996's titles like Quake more playable.
Win95/DOS 7.1 - P233 MMX (@2.5 x 100 FSB), Diamond Viper V330 AGP, SB16 CT2800
Win98 - K6-2+ 500, GF2 MX, SB AWE 64 CT4500, SBLive CT4780
Win98 - Pentium III 1000, GF2 GTS, SBLive CT4760
WinXP - Athlon 64 3200+, GF 7800 GS, Audigy 2 ZS
Reply 8 of 61, by Shponglefan
drone16 wrote on 2024-04-24, 13:39:
Namrok wrote on 2024-04-24, 13:34:
It has to be 3dfx, simply because I did not get it when I was young, 🤣
You could technically do both. The Riva 128 is a 2D/3D card. It would take the place of the Millennium II.
Although the Millennium II is a fine choice for a build of that era.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 9 of 61, by Shponglefan
AFAIK, the highest end 3D cards for 1997 would either be the 6MB Canopus Pure3D Voodoo 1 or Quantum's dual Voodoo 1 SLI card.
Though the latter is basically unobtainable these days.
Reply 10 of 61, by drone16
Shponglefan wrote on 2024-04-24, 13:42:
I tried to look for Riva 128 in PCI flavour (AFAIK there was no AGP on 1997 MBs). It was scarce and too expensive. I already invested in Voodoo2 anyways. $210 AUD damn :)
Reply 11 of 61, by jheronimus
drone16 wrote on 2024-04-24, 13:16:
Total Commander still supports Win9x, even the latest versions
IMO Win95 might be better as long as you use something like OSR2.1 — just needs less RAM, works faster because it doesn't have IE integration like OSR2.5 or Win98.
MR BIOS catalog
Unicore catalog
Reply 13 of 61, by drone16
Descent and Descent II are my target games. Left hand on keypad, right on the mouse. All keypad keys are mapped. Burn the reflexes into your spine, so you don't think when pulling off a crazy 3D curve, your fingers just did it for you 😀
Are there still multiplayer servers around?
Reply 14 of 61, by Shponglefan
drone16 wrote on 2024-04-24, 13:48:
I tried to look for Riva 128 in PCI flavour (AFAIK there was no AGP on 1997 MBs). It was scarce and too expensive. I already invested in Voodoo2 anyways. $210 AUD damn 😀
The AGP spec was released mid-1997 and there were AGP options (motherboards + graphic cards) available later that year.
Voodoo2 is a 1998 card anyway... 😉
Reply 15 of 61, by dominusprog
Well, Trio64 is a better choice for DOS, especially with S3 VBE installed.
Reply 16 of 61, by revolstar
I'd stick with Win95 for period correctness.
Win98 rig: Athlon XP 2500+/512MB RAM/Gigabyte GA-7VT600/SB Audigy/GF FX5700/Voodoo2 12MB
WinXP rig: HP RP5800 - Pentium G850/2GB RAM/GF GT530 1GB
Amiga: A600/2MB RAM
PS3: Slim, CFW, mostly for RetroArch & PSX games
PS2: Slim, FMCB
Reply 18 of 61, by Minutemanqvs
Wait, what? Are these the prices now? (Edit: ah, AUD, then it's fine!)
Ok I have 2 Voodoo 3 for sale then.
But yes, voodoo 2 is a nice choice.
Searching a Nexgen Nx586 with FPU, PM me if you have one. I have some Athlon MP systems and cookies.
Reply 19 of 61, by havli
Shponglefan wrote on 2024-04-24, 15:31:
Most of them were manufactured in 1998 or later, sure... but V2 was anounced in November 1997, so for me it would be good fit for 1997 PC, along with PII 300.
