First post, by Grzyb
I've just learned that Windows 98SE won't install on a 386 - the minimum is 486.
Any idea why?
Is this just artificial limitation, so that nobody complains that it runs sluggish on a 386 ?
Or it actually uses 486 instructions somewhere?
Is it possible to make it run on a 386 via some patch, perhaps something like 98lite?
I don't really care about using it on a 386, but it's hard to believe that a DOS-based pseudo-OS needs more.
Seriously, it's only updated Windows 95 !
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 1 of 9, by Nexxen
https://www.youtube.com/watch?v=zBu0bSWI9eo
Wikipedia:
Users can bypass processor requirement checks with the undocumented /NM setup switch. This allows installation on computers with processors as old as the Intel 80386.[85]
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 2 of 9, by rmay635703
I had Windows 98se running on 8mb ram with a 386, the mouse cursor would hop around and freeze any time there was some sort of activity
Reply 3 of 9, by CoffeeOne
rmay635703 wrote on 2024-04-26, 17:13:
8MB is not enough for Windows 98SE. Even with a faster Pentium CPU. You should have done the test with 32MB RAM for example.
EDIT: The video above is like that, just with Windows95. But there a super slow harddisk (notebook harddisk with 4200RPM?) was taken to make things worse. But yes, 386DX for sure will be slow, haha.
Reply 4 of 9, by CoffeeOne
Grzyb wrote on 2024-04-26, 15:49:
I've just learned that Windows 98SE won't install on a 386 - the minimum is 486. Any idea why? Is this just artificial limitatio […]
Any idea why?
Yes, I believe it is about that:
.... "Is this just artificial limitation, so that nobody complains that it runs sluggish on a 386 ?" ....
It is already slow on a 486DX2/66.
On the other hand I personally enjoy running Win98SE on 486 machines, but nearly always take an Am5x86 (133 or overclocked to 160) for it. It is ok then (for me at least), don't use it for gaming.
Reply 5 of 9, by rmay635703
CoffeeOne wrote on 2024-04-26, 19:56:
I didn’t have compatible ram to install more than 8mb, honestly it ran better than it had any right to but I can report Windows 98 can run on less than 16mb
Reply 7 of 9, by Grzyb
OK, so the limitation is totally artificial, thanks all!
Reply 8 of 9, by jakethompson1
Grzyb wrote on 2024-04-27, 01:55:
It isn't completely artificial: https://devblogs.microsoft.com/oldnewthing/20 … 506-00/?p=39463
Windows NT 4 dropped support for the 80386 processor, requiring a minimum of an 80486, so it could take advantage of this instruction. Windows 98 still had to support the 80386, so it couldn’t.
So how did Windows 98 manage to implement an operation that was not supported by the CPU?
Windows 98 detected whether you had a CPU that supported the new XADD instruction. If not, then it used an alternate mechanism which was mind-bogglingly slow: It called a driver whenever you wanted to increment or decrement a variable.
Also, if you have an extremely early 80386 chip like in a Compaq Deskpro 386, it could be an early version with broken and/or buggy 32-bit support. More about it on that same blog.
Reply 9 of 9, by Grzyb
OK, but it seems that both 98FE and 98SE contain the same code for 386 support.
The only difference is in the installation program.
On the other hand, modern Linux kernels completely lack the 386 code - no way to compile a 386-compatible binary.
I guess it was the same with OS/2 Warp 4 and Windows NT 4.0.
