First post, by 385387386
Intel 80486 DX4 @ 120MHz, 60MHz*2, Write Back, 3.3v
Cyrix 5x86 (M1sc) 100GP @ 120MHz, 60*2, LESSR: enabled in BIOS, Linear Burst: enabled in BIOS, 3.3v
Amount of ram: 32MB
RAM type: EDO mode enabled in BIOS
Graphics Card: S3 Stealth 3D, 4MB RAM
Motherboard: M919
L2 Cache: not available
NOTE:
@66MHz FSB both CPU entered boot screen but freezed.
@50MHz FSB, Intel 80486DX4 can enter DOS prompt at 150MHz, but freeze at loading test.
My first PC (1997)
IBM 6x86mx PR200
BIOSTAR M5ATA
16MB SDRAM
Now upgraded to Cyrix MII 291.5MHz (maybe PR400)
Reply 1 of 31, by theelf
Hi, quake & doom benchmarks what screen size? what version? thanks
Reply 2 of 31, by dominusprog
What’s the point of installing a DX4/586 processor without L2 cache?
Reply 3 of 31, by theelf
dominusprog wrote on 2024-05-04, 10:56:
I have a cyrix 5x86 without L2. After many test, i checked the L2 cache did not make almost any positive difference, in fact, oposite
Reply 4 of 31, by Sphere478
theelf wrote on 2024-05-04, 16:49:
That’s odd..
Btw, I’ve pondered how a pod would do against a 120gp in a all out OC competition
Any chance you have a POD?
Sphere's PCB projects.
Reply 5 of 31, by BitWrangler
DId you have a fan on the cyrix? passive cooling from the stock heatsinks isn't enough really on 100mhz parts at 120.
Reply 6 of 31, by theelf
Sphere478 wrote on 2024-05-04, 17:21:
That’s odd.. […]
That’s odd..
No sorry, i dont have a POD, and sadly i dont find good data to compare. I was checking phil database, but is not clear to me if quake results from people are fullscreen or not, then impossible to compare data
BitWrangler wrote on 2024-05-04, 17:49:
Hi, i used the cx586 for years without any air cooling, just a heatsink. I addapted one from socket 370 and the cyrix is always in good temp. Im running at 4v
Reply 7 of 31, by Sphere478
theelf wrote on 2024-05-04, 18:13:
No sorry, i dont have a POD, and sadly i dont find good data to compare. I was checking phil database, but is not clear to me if […]
That’s odd.. […]
That’s odd..
When comparing to pentium, it’s probably wise to disregard quake results as quake used some special Intel only tricks here
Cyrix got some undeserved criticism about their floating point unit because of quake it wasn’t that cyrix had a bad floating point unit it was that quake figured out a way to make the Intel one run very well using kind of an unintended trick. Which is nice, but is kind of a little bit unfair in the competition.
Reply 8 of 31, by theelf
Sphere478 wrote on 2024-05-05, 01:05:
That’s odd..
Beside software like autocad, etc i cant think what else in dos use fpu and can use for benchmark and compare
Reply 9 of 31, by rasz_pl
More specifically special Pentium trick. Quake was not meant to be playable on 486, thus testing on 486 doesnt make much sense.
Its funny to think about people calling Michael Abrash mister Quake ;]
Reply 10 of 31, by theelf
rasz_pl wrote on 2024-05-05, 12:52:
It make all sense if you want to compare high end 486 to pentium, because one of the idea of build a high end 486 is to test software from latest dos era, and first windows 9x era too
Reply 11 of 31, by dominusprog
That's interesting, because when I upgraded the cache on my DX2-66 from 128 to 256KiB it improved the performance. I can imagine that removing the entire cache can affect the performance.
Reply 12 of 31, by theelf
dominusprog wrote on 2024-05-05, 18:51:
Same here in various 486 i have, including a IBM SX25 upgraded to DX4100, that get a nice improvement from L2 cache both at 25 and 100mhz, 5 to 10% aprox, and a TX DLC40mhz that get a HUGH improvement with L2, more or less 10 to 20%
But with this board and cyrix CPU, i did not see (almost) any improvement, like 1% to none, and to keep stability i need to use 3-1-1-1 in fact using L2 make system slower
Reply 13 of 31, by Disruptor
We're not talking about FSB speeds that allow a -1-1-1 burst.
Please read this here: 486 board with UMC 8881E/8886B: The winner is: EDO without L2 (if your only other option is L2 at 3-2-2-2)
Reply 14 of 31, by dominusprog
Disruptor wrote on 2024-05-07, 19:19:
Sure, thanks for the link.
Reply 15 of 31, by megatron-uk
I think that's a really quite contrived example. mkarcher clearly recognises that Quake, in particular, is not very cache friendly (the memory access being somewhat 'random'); one would suspect that a larger cache would alleviate this to a certain degree since the hit rate would surely increase.
The above may be true for certain single threaded workloads, for certain applications, but I suspect that as soon as you encounter software that has relatively standard memory access patterns (i.e large data arrays in contiguous memory locations, instructions without wild branching patterns) or you move to a mixed software load like in Windows (or Linux, or OS/2) then the assumption will go out of the window.
There has been a lot of research into the design and sizing of cache memory over many decades, and unless the implementation is completely and utterly broken (which is always possible) or an exploit results in the performance increase being negated by security measures (e.g. cache flushing on context change), in the majority of workloads it is better to have it in place than not.
https://www.target-earth.net
Reply 16 of 31, by mkarcher
megatron-uk wrote on 2024-05-08, 08:03:
While this is clearly true, special circumstances (and FSB60 on a 486 mainboard clearly counts as "special circumstance") may invalidate otherwise perfectly well working cache strategies. Note that in those speed tests, I had to insert a memory read wait state at FSB60 as soon as I added the cache. This makes the cache miss performance plummet from 76MB/sequential read to 54MB/s sequential read. At the same time, writes also suffer, because the possibly required cache update (3 clocks) takes longer than the actual write to RAM on a page hit (just 2 clocks). The cache subsystem is clearly not designed to deliver adequate performance at FSB60, at least with the cache chips I used for that test. On the other hand, the EDO RAM that "won" the competition is able to handle FSB60 quite well.
A cache only makes sense if it is significantly faster than RAM, and the cache management overhead is negligible. Both is not the case with the 15ns cache chips and the required 3-clock leadoff, if I am able to run EDO RAM without extra waitstates at 4-2-2-2. Basically the thread shows that an unfit cache does not help if the system has high-performance RAM. That 15ns cache (including a 15ns tag) is unfit for FSB60.
Reply 17 of 31, by rasz_pl
Its more of Quake exuberating exacerbating and exposing poorly implemented caches. Same situation on socket 5/7 in non PB configurations.
Reply 18 of 31, by 385387386
theelf wrote on 2024-05-04, 10:17:
Hi, I will check the version at this weekend
My first PC (1997)
IBM 6x86mx PR200
BIOSTAR M5ATA
16MB SDRAM
Reply 19 of 31, by 385387386
A big heatsink with active USB powered fan.
My first PC (1997)
IBM 6x86mx PR200
BIOSTAR M5ATA
16MB SDRAM
