VGMSlap - DOS OPL1/2/3 VGM Player
First post, by MrKsoft
I recently released VGMSlap, a player for OPL1/2/3 VGM files under MS-DOS. It is certainly not the first and definitely will not be the last VGM player for DOS - but it's mine!
The attachment vgmslap.png is no longer available
I wrote it as a learning experience for both MS-DOS programming and C in general, so it might still be rough around the edges as I'm still pretty inexperienced. There's definitely room for major performance improvements and more features. However, it does do what it says it does, and I think that warrants a public release!
Compared to some of the other players available on DOS, benefits of VGMSlap include a visual channel display in a colorful 80x50 screen mode, support for playlists, and the ability to play Dual-OPL2 VGMs with the correct Sound Blaster Pro 1.0 panning even on OPL3. It should run okay on a 386 or higher with VGA (as I said, definitely room for performance improvements!). Cards with OPL2, Dual-OPL2 and OPL3 are all supported.
VGMSlap is open source and distributed under the MIT License, targeting Open Watcom C 2.0. Code and releases can be found on GitHub: https://github.com/MrKsoft/vgmslap
I would be interested in hearing your experiences with VGMSlap and (constructive) criticism on fixing bugs and making improvements. Enjoy!
The OPL Archive - Preserving MS-DOS music in a unified format!
Reply 1 of 25, by bakemono
It seems like the player can crash sometimes if the VGM file does not end with a 0x66 command. (This includes all files generated with MIDI-to-VGM translator.) It didn't happen in dosbox, but happened on my 286. The problem went away when I added the 0x66 byte.
Attaching VGM test file...
Wreckage reimagined on itch: https://90soft90.itch.io/wreckage-dash
Reply 2 of 25, by MrKsoft
Thanks for the test file. It makes sense, since 0x66 is the "end of sound data" command and any properly formed VGM should have it, but I don't want it unceremoniously crashing either. One mitigation I could do at least is better bounds checking to see if the player overruns the end of a file. However if the file has a GD3 tag but no 0x66 before that, it is going to try reading the GD3 tag as a command and either send garbage to the OPL3 or quit due to encountering an unknown VGM command.
Reply 3 of 25, by OPLx
Great to see another VGM player for MS-DOS! Nice!
Reply 4 of 25, by MrKsoft
SBVGM is still the gold standard, though! Time-tested and versatile. I just wanted something flashier and OPL centric 😀
@bakemono - I committed a fix for VGMs missing the 0x66 command, and it will be incorporated into the next release.
Reply 5 of 25, by OPLx
MrKsoft wrote on 2024-05-08, 21:20:
Thanks! 😀 I think the more new MS-DOS software the better. So jealous of how many new things are released for the other older platforms in comparison.
Reply 6 of 25, by OPLx
With a DIVIDER setting of 1, VGMs play very slowly on my Pentium III - 450 MHz machine. I guess something is skipping updates?
[Edit]
It might be because I was running within WinME ... will have to check when I have time later.
Reply 7 of 25, by MrKsoft
Yeah, I should have put that in the readme - it is probably not going to work in Windows because it sets up an ISR8 handler and changes the PIT frequency to 44100hz/DIVIDER. IIRC Windows in protected mode prevents this from working as expected. There are probably more friendly ways to do timing but this one made sense to me as a learner and was able to trivially get me the 44100hz precision VGMs ask for.
Reply 8 of 25, by OPLx
MrKsoft wrote on 2024-05-11, 16:00:
No problem! It works in a pure DOS environment. Thanks for the update.
Reply 9 of 25, by MrKsoft
R2 is now available, with lots of fixes: https://github.com/MrKsoft/vgmslap/releases/tag/r2
  • Rewrote screen update code to only write screen areas when the actual chip data changes instead of refreshing the whole thing. Performance is only marginally better overall, but it is much more responsive on under-specced systems.
  • OPL2 detection now actually works outside of emulation.
  • Disabled interrupt timer mistakenly left on while decompressing VGZs, now it completes a lot faster.
  • Improved handling of VGMs that are missing "end of song data" command (0x66).
  • Fixed a mistake in sample position calculation; all commands advanced the position counter even if there were multiple commands in one sample. This may have been a contributing factor to the DIVIDER configuration setting making complicated VGMs sound weird, so setting a higher DIVIDER should be less of a problem now!
  • Fixed issue where playlist entries would fail to load on some systems.
  • Fixed OPL register/data write delays being reversed.
  • Error messages related to file loading are more descriptive.
Reply 10 of 25, by MrKsoft
R3 has just been released: https://github.com/MrKsoft/vgmslap/releases/tag/r3
The attachment vgmslap-r3.png is no longer available
  • Added some bars at the bottom of the screen showing channel output levels by simulating the ADSR rates. There are a few edge cases where it isn't accurate but overall it provides a good approximation.
  • Slightly better representation of percussion mode - the note-on indicators light up now, and change to a ! symbol to show they are percussion. This will likely be expanded later to a dedicated percussion mode display of some kind.
  • Fixed 4-op channel display - all 6 channels that were capable of 4-op were shown combined, even if only a single channel had the 4-op flag enabled.
  • Channels display in numerical order if 4-op mode is off.
  • Struggle bus mode fixed to not leave an empty channel table on screen - this was a mistake introduced when reworking the drawing code. It also now leaves the system in 80x25 text mode instead of unnecessarily switching to 80x50.
  • Under the hood, the source code has been restructured. It has been split out from a single gigantic file, and now has a proper build system! Rejoice!
Reply 11 of 25, by wbahnassi
Hi. Thanks for the nice tool. I was trying VGMSlap the other day to capture instruments from actual game music and replicate them inside of Adlib Tracker 2.
However, several parameters are shown "interpreted" in VGMSlap rather than actual register values. AdTrack2 takes the register numbers without much fumbling AFAICT.
Is it possible to have a mode where you show actual register values instead of converting them to more "human understandable" display?
Things like wave form shape, feedback, volume (I think this is reversed) and so on.
Another nice to have feature is if you can consume .DRO files directly. Not very important, but more of a convenience feature, since DRO->VGM conversion tools exist.
Otherwise, very cool! Thanks, and keep it up!
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 12 of 25, by MrKsoft
wbahnassi wrote on 2024-07-24, 12:45:
Hi. Thanks for the nice tool. I was trying VGMSlap the other day to capture instruments from actual game music and replicate the […]
I can't guarantee it, but I could look into having it as an alternate display mode in the future alongside some others I'm thinking of (need some code shuffling to untie some of the interpretation/drawing code first). The register values are stored as-is and the only change is what's being put on screen as a result of those numbers, so the capability is there. That said the goal of the program is mostly to look nice and make it more human understandable.
If you're looking to do instrument rips, have you tried importing VGMs using OPL3BankEditor? I've used that in the past and additionally worked with it to help verify results for what VGMSlap is putting on screen. It may not be 100% ideal for importing into AT2 if you're doing 4-op, though - I don't think it exports any 4-op capable formats that AT2 understands. (It does for Furnace, though)
Regarding chip values, VGMSlap stays pretty close to what's actually being put into the chip. Even the "interpreted" values are tied directly to the values in the register. You can cross reference with this mirror of the well-known OPL3 Programmer's Guide. For example, if VGMSlap shows the feedback value "/4" it aligns to the same "/4" value as written in the guide, which is register value 3. Heck, I've been doing this so much now that I've started to memorize the mapping between them. 😀
In comparing to tracker programs, the most common differences seem to be in how the volume is interpreted. The OPL internally uses "volume attenuation" so 0 really is the loudest value and 3F really is the quietest (or highest attenuation). I believe AT2 inverts this intentionally because that is more like what a musician would expect, that the highest value equals the highest volume. Just doing a cursory look at AT2, which I haven't used in a few years, I think everything else lines up as expected. (I think OPL3BankEditor mentioned above also inverts volume, and Sustain as well)
Lastly, DRO support, while simple, not a priority. It used to be more popular, but is poorly suited to casual listening, and seems to mostly be used now as an intermediary format on the way to VGM anyway. Heck, all the VGM work that I do bypasses DRO completely with a patched DOSBox. I have done some preparatory work to decouple the VGM reading from the rest of the program, though, so who knows what the future will hold?
Reply 13 of 25, by wbahnassi
Thank you. I will give OPL3BankEditor a try. Last time I used it gave me some difficulties to make it even output sound. And yes, DRO is just for convenience.. perhaps it would be even better if DOSBox actually writes out VGM instead of DRO from the get go.
Reply 14 of 25, by wbahnassi
Gave OPL3BankEditor another go. Indeed it can import instruments from VGM files, but it's quite well hidden.. plus the UI controls to select the instruments to import is broken. The list control for selecting instruments is supposed to support multi-select but actually it is set to single-select. Thus, even the Select All button cannot do its function. So you have to click each instrument one-by-one and import them like that.
Once in, the program indeed shows a very good representation of all the register values, and moving them to AdTrak2 is straightforward.
Thanks again for both your suggestion and VGMSlap 🙂
Reply 15 of 25, by MrKsoft
Published R4 today, basically a hotfix release: https://github.com/MrKsoft/vgmslap/releases/tag/r4
Turns out there was a sizable memory leak on long playlists due to the GD3 tag handling. Whoops!
Reply 16 of 25, by miragu
I'm glad to have found your new player. The visualizer is very pleasing and everything works great on my 486DX2 with Sound Blaster 16.
I'm testing VGMs from a downloaded OPL Archive and it would be most convenient if the player had a file browser. Is that something you would be willing to add?
Keep it up!
Reply 17 of 25, by theelf
Hi, i made a small frontend
Just need to be in same directory vgmslap.exe and edit vgmfront.cfg to add a VGM directory.
I wanted to have long names, then the frontend not read directly from dierctory, but from files. 2 kind of files, dir.vgd and file.vgd
dir.vgd is when only directory, and file.vgd
for example whe have the VGM in c:\audio\vgmslap\vgms
inside vgms for example whe have YM3812 and YM262 directories, inside this directories the vgm files
then we need to have a dir.vgm in c:\audio\vgmslap\vgms that contain something like
YM3812 Music;YM3812
OPL3 power;YM262
and inside YM3812 a file.vgd file with somethinmg like this
01 Radiance of Esmeranti.vgm;01.vgm
02 Departure.vgm;02.vgm
03 To The World of Darkness.vgm;03.vgm
04 Dark Messenger.vgm;04.vgm
05 Victory.vgm;05.vgm
06 Subterranean City.vgm;06.vgm
07 Beyond The Caves.vgm;07.vgm
08 World of Trees.vgm;08.vgm
09 A Moment's Rest.vgm;09.vgm
10 World of Ice.vgm;10.vgm
11 World of Decay.vgm;11.vgm
12 Secluded Town.vgm;12.vgm
13 World of Gold.vgm;13.vgm
14 World of Fire.vgm;14.vgm
15 World of Wonder.vgm;15.vgm
16 Demon King.vgm;16.vgm
17 To a New Adventure.vgm;17.vgm
In the frontend if press enter in a vgm, launch vgmslap.exe with only this file, but if we press space key, will open vgmslap with the playlist of this directory
the file names must have 74 or less characters to fit screen and cannot mix vgm files and directories
it work great for me, i have a big collection of VGM files in a 1x mitsumi CDrom on a 286 PC, and load names fast, even this slow cd and CPU
The attachment Image1.png is no longer available
The attachment VGMFRONT.zip is no longer available
miragu wrote on 2025-05-04, 18:25:
Keep it up!
maybe it works for you my frontend
Reply 18 of 25, by MrKsoft
Hey, this is a great solution! Thanks!
While I have not done much development work on VGMSlap as of recent, an integrated file browser is still on the roadmap. I do find that seeing longer names is very helpful for VGMs and I will probably aim to support reading 4DOS-style DESCRIPT.ION files for that. There are some other tasks I want to complete before moving on to this, first and foremost supporting decompressing VGZs straight to memory without writing a temp file (so implementing EMS or XMS support). I'm sure I'll get these done... Eventually(tm).
Reply 19 of 25, by theelf
MrKsoft wrote on 2025-07-28, 20:54:
Thank you! i love vgmslap, is amazing
The frontend i wrote works really good for me, I made a small python script, that create dir.vdd and file.vgd automatically, and i just "finish" my opl vgm collection, with full names, i really enjoy everyday listen to opl music
thanks. Tomorrow i will upload a small new version of frontend with some fixes, and i dont know if is possible to upload here my full vgm directory with frontend vgds with long names
