Reply 1700 of 1810, by zaphod77
i've finally tracked down some of the infamous yamaha softsynth hacks.
i now have vstis for
s-yxg20 (the basic gm only version of sy50) (didn't have it before, kinda pointless)
s-yxg2006LE (the xglite synth extracted from the midiradio player, already known, better than the above)
ymf-754 HiEnd (sy50xg hacked to use the ymf-754's samples, with a 9 megabyte sample table. plays back xg midis fine)
"Vampire" (seems to the the same as the above, and even calls itself ymf-754 HiEnd still, what's the difference? it's EXACTLY the same sample table, just with a different name)
"Tyrus" (has a gigabyte sample table, presumably ripped from a tyros keyboard? doesn't seem to be as nice on mu-50 composed midis as the others, but does seem to understand the effects. think of sc-55 vs sc-88 pro. the patches are in the right banks for xg playback)
still waiting for an actual mu-50 sample table rip to try and plug into one of these or the s-y50xg portable with external tables version.
Reply 1701 of 1810, by Falcosoft
zaphod77 wrote on 2024-04-29, 20:59:
i've finally tracked down some of the infamous yamaha softsynth hacks. […]
I know/have many of them except "Vampire". It somewhat surprises me that it resembles mostly ymf-754. I thought it was even bigger than "Tyrus" with many samples/Midi systems integrated.
Here Roland User's post suggests that "Vampire" has a sample size around ~2GB:
Re: Falcosoft Soundfont Midi Player + Munt VSTi + BassMidi VSTi
Website, Facebook, Youtube
VST Midi Driver Midi Mapper
Reply 1703 of 1810, by Roland User
Falcosoft wrote on 2024-04-29, 21:14:
Hi, I know/have many of them except "Vampire". It somewhat surprises me that it resembles mostly ymf-754. I thought it was even […]
Yes , in YAMAHA Vampire Samples size 2 GB , however , because Wlad Rever not want free distribute this synthesier , instead of this Wlad Rever want distribute this synthesizer per donate basis , I as tester was be forced remove Vampire form my SynthPack , however , because the I do SynthPack for me and then share , I replace Vampire to YMF-754 , this was do what not have port without sounds. If you want have Vampire , you can contact me and I remapin you to Wlad Rever )
Reply 1704 of 1810, by Roland User
zaphod77 wrote on 2024-04-30, 03:01:
At one point "tyrus" was switched to the "vampire" engine.
i'm still not sure what that actually means, and all the discussion is in russian, so i can't really join in and ask questions.
If you want , you can ask me , I as much as I can answer to you ) this can do from this topic if FalcoSoft do not mind , or this can do in personal messages )
Reply 1707 of 1810, by MusicallyInspired
Has the topic of pitch bend range sensitivity been brought up regarding the OPL3GM VSTi plugin? So far I've tried 4 different plugins and none of them (OPL3GM included) supports the 14-bit MIDI RPN for adjusting pitch bend sensitivity. At least, not in the traditional method. ADLPlug doesn't, JuceOPL doesn't, and Datajake's OPL3 VSTi doesn't either. Is this something that can be added to OPL3GM or is it already a feature that's accessible in some other way somehow?
Yamaha FB-01/IMFC SCI tools thread
My Github
Roland SC-55 Music Packs - Duke Nukem 3D, Doom, and more.
Reply 1709 of 1810, by MusicallyInspired
You know what, I am sending the correct data but as I was typing this response I remembered that Cakewalk stupidly does not send sysex to VSTi plugins. This appears to also be the case with RPNs. Fricking Cakewalk...
My Github
Reply 1711 of 1810, by Falcosoft
MusicallyInspired wrote on 2024-05-06, 19:08:
OPL3GM VSTi definitely supports RPN(0,0) pitch bend sensitivity. Valid values are even broader than with most other synths from Yamaha/Roland. Roland usually only specifies 0-24 semitones as valid values.
But you do not have full 14-bit resolution since it is not needed. The LSB part is ignored.
32.8 KiB
Here is a Midi file for testing that uses 36 semitones as Pitch bend sensitivity right from the beginning on channel 11 (Saw Wave):
sor-st1.zip
4.95 KiB
11 downloads
Reply 1713 of 1810, by Falcosoft
zaphod77 wrote on 2024-05-07, 07:10:
apogee driver does support it, but win9x driver does not. I looked in the source.
You can also look at the source of the engine of OPL3GM VSTi:
https://github.com/Falcosoft/OPLl3emu4v/blob/ … rc/OPLSynth.cpp
The relevant lines are from 627.
Reply 1714 of 1810, by Roland User
MusicallyInspired wrote on 2024-05-06, 20:31:
About Cakewalk with use embeded VST Host in Cakewalk I can say what this solution very curve and very bad , this VST Host can not work with XG if need use any banks which different on GM , embeded host easy ignore all cc00 / cc32 messagegs , also embeded host ignore all messages for insert effects group. This I learned from one musician wich try make XG music in Sonar use embeded VST Host for YAMAHA Vampire and YAMAHA YMF-754. That's why I think what you have same problem )
However if use Cakewalk and output MIDI to any other port for example LoopMIDI + SAVIHost , Cakewalk will process all MIDI messages correctly )
Reply 1715 of 1810, by zaphod77
Falcosoft wrote on 2024-05-07, 07:17:
You can also look at the source of the engine of OPL3GM VSTi: https://github.com/Falcosoft/OPLl3emu4v/blob/ … rc/OPLSynth.cpp Th […]
as i recall you intentionally did this because the real win9x driver also ignored it,
i based this of of
https://github.com/datajake1999/OPL3GM_VSTi/b … 9x/opl3midi.cpp
which doesn't seem to have parser for that RPN
and
https://github.com/datajake1999/OPL3GM_VSTi/b … gee/al_midi.cpp
which does have a parser for it.
Reply 1716 of 1810, by Falcosoft
zaphod77 wrote on 2024-05-07, 18:36:
Yes, of course. I had no intention to replicate all the bugs and deficiencies of the Win9x driver.
The plugin also supports Modulation wheel controller messages and GS/XG/GM2 style multiple drum channels among others that you cannot find in the Win9x driver.
Reply 1717 of 1810, by Roland User
Hi Zoltan!
You have no desire do expand your plugin WinMultMIDI from 4 parts to 16 parts ? In teory this will give users use up to 16 different synthesizers with use one synth one part and this as I think will be verry cool ) because so can to scale polyphony of synth or we can use one synth per one part and one instrument )
If this do , you create full-fledged MIDI sequencer in one plugin )
Also this give up to 256 MIDI tracks if use per 16 tracks on everyone of 16 ports
Reply 1719 of 1810, by Roland User
Yes , but working this very slow
If you sayd about my post to Falcosoft , that you not understand my idea ) I sayd not more chips in OPL3 synthesizer , instead of this I offered make VST MIDI Sequancer in which user can custom route output per channel with select any synth for out )
