First post, by laios67
Trying to start Max Payne but no succes . The configuration is Pentium 3 1000 Voodoo 3 3000 drivers 1.07 . Max payne v1.05 but also tried all the older with every fix avaiable .I get always the error : "exception FPU precision assumed to be 53bits" anybody knows any remedy for this ?
Pentium III 1ghz Coppermine 750mb SBLive! Voodoo 3 3000 AGP
Compaq Deskpro Pentium III 933 EN 500mb Geforce4MX 440 AGP
Pentium 4 1.8ghz Northwood 500mb Voodoo 3 3500 AGP
Pentium 4 1.7 ghz Northwood 1gb Voodoo3 3000 AGP
Reply 1 of 28, by rain
What is your directx version? May causes problems
Reply 2 of 28, by laios67
Forgot to mention the os is windows 98 . The installed is version 9 .
Reply 3 of 28, by BEEN_Nath_58
For V3, I would stick at DX7 at highest
Reply 4 of 28, by laios67
The game itself asks for DX8 to be installed
Reply 5 of 28, by akula65
And did you actually run the DX8 installer? Unfortunately, DirectX9 (pick any version release) does NOT necessarily install everything that previous DirectX versions might have provided. So I would suggest running the DirectX 8 installer. The following ancient pages may help with doing this and give you some useful tips once you get up and running (i.e., graphics double buffering vs triple buffering for Voodoo3):
README: https://web.archive.org/web/20030610032748/ht … port/index.html
Troubleshooting: https://web.archive.org/web/20030213140008fw_ … ml/troubles.htm
Playing Max Payne: https://web.archive.org/web/20030623194144fw_ … tml/playing.htm
Reply 6 of 28, by laios67
yes I also did that otherwise there is another error about that game needs Dx8 to be installed
Reply 7 of 28, by akula65
Did you by any chance try to run the Version 1.05 Max Payne demo on this particular machine before you installed the full game?
Reply 8 of 28, by eddman
akula65 wrote on 2024-05-07, 20:31:
Last I checked only the releases starting with Feb 2007 lack the base DX files for 98 (they cannot be directly installed on 98 anyway). IINM Dec 2006 should include everything.
Reply 9 of 28, by laios67
no I didn't run the demo
Reply 11 of 28, by Matchstick
laios67 wrote on 2024-05-07, 12:52:
Pretty sure this is the CPU's FPU and not the GPU error.
Reply 13 of 28, by BEEN_Nath_58
Matchstick wrote on 2024-05-08, 21:50:
BEEN_Nath_58 wrote on 2024-05-07, 19:07:
Voodoo 3 is 100% completely DX9.3c compatible.
In my case installing anything over DX8 would corrupt the visuals on any game run/game exit so that's why I decided to stick to DX7
Reply 14 of 28, by eddman
BEEN_Nath_58 wrote on 2024-05-09, 03:19:
Max Payne does not even launch without having DX8 or higher installed. It requires d3d8.dll.
Reply 15 of 28, by BEEN_Nath_58
eddman wrote on 2024-05-09, 07:45:
In other words, I was disregarding V3 for Max Payne... (I know it uses DX8)
Reply 16 of 28, by leileilol
Max Payne officially supports the 3dfx Voodoo3 (it's the minimum 3dfx hardware that is supported due to how it deals with texture memory) so it's something else.
There should be a rule about the awful common blind advice of directx downgrading. I personally never done it to fix some game and never suggest it
Debian's fucked
Reply 17 of 28, by Matchstick
That is very weird. I am running a Voodoo 3 3000 on windows 98se with DX9.3c and I have zero issues. There is something else wrong with your setup if you can't run anything over DX7.
Reply 18 of 28, by BEEN_Nath_58
Matchstick wrote on 2024-05-09, 16:25:
I didn't install DX9, the problem happened after DX8 installation so I never bothered trying DX9
Reply 19 of 28, by laios67
Curiously I found a similar question about Max Payne 2 in an archived post at 3DRealms forum:
Hmm yes indeed same issue although in this case is windows xp . I'll see what is running in the background
after a while...
I closed almost everything of background but the same
