First post, by JonnyBoy
How do i load cutom made nukem maps. Ive tried eduke but it doesn't seem to work caz i keep getting an error & ive tried some other programs but they keep trying to load under dos & i can't change it so that they load under dosbox...
Any help would be apprichated as if completed nukem & i want to keep playing it...
Reply 1 of 3, by avatar_58
If my memory isn't completely shot, you use -
Duke3d -map MAPNAME.MAP
That should do it.
Reply 2 of 3, by leileilol
you can also load maps through the new game>user map menu in eduke
Debian's fucked
Reply 3 of 3, by JonnyBoy
Yea i tried eduke but the only maps that appeared were the ones that you play in story mode. Here is where i got the files installed c:\duke3d or should they be in c:\duke3d\maps...
