First post, by pete8475
- Oldbie
I can never just leave well enough alone and always end up playing around with and tweaking my old hardware.
Anyway for a while now I've wanted to see what the best speed I could get out of this 1.4 is and with a small wire mod to the socket on an Asus TUSL2-C to give it some extra voltage I think I've got my answer. It seems stable so far at 1700, crashed in 3D Mark 2001 at 1711 and it will post at 1733 but will not successfully boot into Windows.
I'll post some pics of the wire mod and the system later today or maybe tomorrow but the specs are as follows:
Asus TUSL2-C
2 x 256MB PC133 CL2 RAM
EVGA Quadro FX 3000 256MB
64GB CF card for storage
Some quick benchmark results:
1400mhz/Quadro - 133mhz ram 222-7/9
Quake 3 800x600 - 167.0fps
UT2003 botmatch 1024x768 - 38.359749fps
3dmark2000 - 9979
3dmark2001 - 9680
1627mhz/Quadro - 116mhz ram 222-7/9
Quake 3 800x600- 170.1fps
UT2003 botmatch 1024x768 - 39.788456fps
3dmark2000 - 10470
3dmark2001 - 9912
1648/Quadro - 117.8mhz ram 222-7/9
Quake 3 800x600 - 174.5fps
UT2003 botmatch 1024x768 - 40.391262fps
3dmark2000 - 10472
3dmark2001 - 9963
1680/Quadro - 120.1mhz ram 222-7/9
Quake 3 800x600 - 176.9fps
UT2003 botmatch 1024x768 - 40.943924fps
3dmark2000 - 10724
3dmark2001 - 10086
1700/Quadro - 121.5mhz ram 222-7/9
Quake 3 800x600 - 177.6fps
UT2003 botmatch 1024x768 - 41.354408fps
3dmark2000 - 10836
3dmark2001 - 10216
1711/Quadro - 122.3mhz ram 222-7/9
Quake 3 800x600 - 179.1fps
UT2003 botmatch 1024x768 - 41.614452fps
3dmark2000 - 11386
3dmark2001 - crashes at various points
I'm definitely going to experiment with running the ram at a higher speed too when I can find some time.
aka pete4237.5
