ESS Solo 1 different versions
Reply 80 of 153, by zuldan
4xtx wrote on 2022-05-02, 02:01:
Here's 2 for the collection.
The ES1938MI is currently being used in an EPIA-ITX based project
On the E1938-202 PCI card, do you know what the jumpers do?
Reply 81 of 153, by 4xtx
zuldan wrote on 2024-04-30, 08:24:
From recall it was to enable amplification for passive speakers
YT: https://www.youtube.com/@techdistractions
Reply 82 of 153, by zuldan
4xtx wrote on 2024-05-03, 10:53:
That’s what I thought it was for but why do you need 2 jumpers for that. That’s a lot of combinations for something that’s on/off. Weird.
Reply 83 of 153, by elszgensa
You need to do it twice because there's two channels. It's not a "logical on/of" but you route each channel through an amplifier or not. Feel free to do only one jumper - you'll see you'll have only one side amplified. Doing it with a single jumper would've required more components and added costs.
Reply 84 of 153, by zuldan
elszgensa wrote on 2024-05-03, 11:57:
Ok that makes perfect sense. Thank you!
Reply 85 of 153, by dancing.sphinx
Hi guys! Which one Solo-1 version would you recommend to purchase?
Main interest - ESFM, Win9X, clean recording from Line-out.
Option 1.
1.XH_mvLa48JbQC3Kb0vUbCpAe8pBYHXKA0BDylFYV-JxQ.8Ge5RlMQ5F6ETJi3yiO-lEoq1jJWcaoxKlb7rq6BpuA
1.F-R8i7a4uw1KPDkAXsNQkQopuQvCKjkbSie5D8wiswfK.uejiE2dbk4JgnV8plUDA1sg_RrSEdr0PZCsEyKH7lKc
1.KenEKba4hQDyngcNmm1unLKLhwZ6iAcW8oWHAnSAjQpy.Rfkqiugyz7wxuoR_ldLYTFDcoYUUM3p9gOy7oIU8ygM
Option 2.
1.R3xy5ra465VEUWmYcJ82emRE6ZPMR2mDRErpl8JP45_E.-85Q7Nrh8q6aT5Q_gR1YkgE1Fq1iXOWff0omva09TMM
Option 3.
1.Unhtlba4_pFbInycRbR8ahE3_JfTNHyHWzn8k9089pvb.VQhVSAhYlHwSiFsEGWqpCQGESYWt8Q2x75KCWbiqKaY
1.WV8rera49bYdzXe7FUN3TVfY97CV23egHdb3tJvT_byd.J8poKnc29r3aIp1uefps-NlbLIJyJfRxtUU80Ntg7ks
1.a4aQtba4x2-mAkViyqBFlOwXxWkuFEV5phnFbSAcz2Um.gAVn5vJ8gPRM4wV_pKsY6ezTU3daEvnRYTIBdn7T4SE
1.nljfjba4MrHpOrC87-OwSqMvMLdhLLCn6SEws28kOrtp.YWXQcIHzfxiAjCpP_10cXko3GFssCopHIS5Ox3O4qbg
Thank you!
P.S. It seems that they are almost the same, but nonetheless...
Reply 86 of 153, by dancing.sphinx
And by the way, do I understand correctly that the ESS Solo-1 is the ONLY PCI card with ESFM capabilities?
Reply 87 of 153, by elszgensa
Uh. Yeah those look to be technically identical. If you want black connectors, and the silkscreen to say "1.1" go with A; B and C for colors and "1.10" silkscreen, or in other words - get whichever's cheapest. Or you could wait a bit for another model to show up, one with a wavetable header (even if unpopulated) - you might not care now, but may change your mind later.
Reply 88 of 153, by dancing.sphinx
Thanks for the advice! One more question: does it make sense to buy an ISA m/b + ESS card for better ESFM quality? In other words, does the Solo-1 have the same analog audio output as its ISA counterparts? (AFAIK there is no any S/PDIF version of the ESS card, which might be a better option)
Reply 89 of 153, by ux-3
Can you use a yamaha wavetable with this card (wavetable header present) in pure DOS games? I know the card works well in dos.
No hanging notes bug or some such?
Retro PC warning: The things you own end up owning you.
Reply 90 of 153, by Demolition-Man
This sound card is driving me crazy. You obviously need the right PC (mainboard). No matter what I do, the sound card always ends up on IRQ10. Therefore not usable in DOS. But I have a question about that. How do you get the game port activated? No jumper, no software config?
Reply 91 of 153, by dancing.sphinx
elszgensa wrote on 2024-05-19, 00:18:
There is also one difference that may not be important, but anyway - variant 1 has a chip labeled "SOLO", the other variants only have a bare chip without the word "SOLO". Is this related to some chip revision or something?
Reply 92 of 153, by elszgensa
You're right, I totally missed that. Whoops. To save you the trouble of rotating those photos, they're H808, K390 and K350 revisions. The K revisions might be worse unless paired with an EEPROM? Probably a good idea to re-skim this thread.
Reply 93 of 153, by Shponglefan
ux-3 wrote on 2024-05-19, 12:35:
If it has a wavetable header, it should work fine with any wavetable daughtercard.
I have an ESS Solo-1 that I added a wavetable header to and I've tested with dozens of games, and for the most part there were no issues.
I reported my test results in this thread: ESS Solo-1 DOS Compatibility Testing on Multiple Systems
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 94 of 153, by ux-3
Shponglefan wrote on 2024-05-19, 22:20:
If it has a wavetable header, it should work fine with any wavetable daughtercard. […]
Thanks. Looking at your signiture, I looked a bit into your 486-33 thread. I am finalizing mine at the moment - at least I hope so. (Solo-1 question was for a different model).
Reply 95 of 153, by appiah4
Wavetable header works 100% bug free.
Reply 96 of 153, by dancing.sphinx
1.e9nsvraNwzDaCVU9ls8b0JQclQBjLrQLaHjmCzkp7QZjKLRTaivsVjst4wY7f7cCPnvnMg.grcL4-oFQ1Lsjx1rtpNRtBN_TeVtiQSdxQGxewIcaSQ?
What do you think of THIS card? It's a very strange revision.
The owner says he was unable to install drivers for 2K/XP. Sometimes the card was defined as "ES1969" and sometimes as "ES1946_1938".
Spoiler
1.WyY5kLaN488PJ3XCA6FfZEAytfrtBJT_uAvFqL8Hx_m5AZasuAOQ-LdQzf-4VZSsuQKTzQ.hXK0U2gmq6JFUdl4ttd8S_YfnqqwKm_uC7FB6VCHHSM?
1.YPUROLaN2Bwnj04RXQVkt2iajimVqvoslqKtJ8T6rCqf-Px_n6n5eJ6t-HqV-fh8kK3_Hg.sVYiJcjp98g61PeMbaOTY7NeU6owbI3M3sxgH9phcR0?
Reply 97 of 153, by fjardest
Hello,
Try cleaning the PCI connector. From the photo, it seems dirty or maybe damaged.
Reply 98 of 153, by LHX
Hi!
I dumped the EEPROM from LWHA331D60 (Soundboard D66) with ES1938S K260 chip. There is almost nothing inside the file. Just "F8DF" hardware ID string.
The attachment 20240528_153537.jpg is no longer available
The attachment 20240528_153551.jpg is no longer available
Have fun!
Reply 99 of 153, by zuldan
Came across this Solo 1 for really cheap. Has a wave table header. I really hope it's the older revision that supports the ESSVOL.com in DOS.
The attachment solo1.png is no longer available
