First post, by _StIwY_
Hello everyone, i just got a Pioneer DVD-104SZ, unfortunately it's affected by some problems. ( I already tried to clean the lens but nothing changed ).
It's pretty noisy, i disassembled the case and turned on with a disc inside. Looks like the laser head gets crazy when the drive try to read the disc.
Sometimes the drive is capable to read the disc for some seconds, but eventually starts again to make noises and that's it.
I recorded a video while CD Speed 99 was working so i can explain better:
https://drive.google.com/file/d/1QTTBs9sNnyyW … iew?usp=sharing
EDIT: Looks like he can read DVD more easily
Reply 1 of 16, by GunKneeNeon
1. Make sure the disc is a working one.
2. Clean the lens using a q-tip with alcohol. (You've already done.)
3. Adjust the power of the reading head by rotating the knob clockwise a little bit. The knob is near the lens, either under or at the side of it. You could use a multimeter to check its resistance while adjusting it. Turning it clockwise will reduce the resistance. Don't turning it too much one time then check to see if it reads the disc normally, if not, repeat the procedure.
4. If none of the above method works, it might be the laser head is dead or the circuit controlling it failed.
Constantly looking for the driver for Acer Magic v1 MPEG decoding card.
Reply 2 of 16, by _StIwY_
GunKneeNeon wrote on 2023-06-01, 10:15:
1. Make sure the disc is a working one. 2. Clean the lens using a q-tip with alcohol. (You've already done.) 3. Adjust the power […]
Thanks for your reply, but i got bad news. I adjusted the knob in a lot of positions but i only managed to get things slightly better.
The DVD are being read a bit better, ( CD Speed 99 still can't complete the benchmark because at some points appears an error )
CD are still problematic like and the laser head goes crazy everytime and gets noisy.
I also used some strong compressed air all over, inside the drive but nothing.
Reply 3 of 16, by GunKneeNeon
@_StIwY_
Note that a disc drive like yours, plays both CD and DVD, has two different heads for CD and DVD respectively, hence the fact that it read DVDs better. There are two knobs there. What you have done, I assume, was to tune the knob for DVD head. So you've noticed the DVDs are read better. You have to locate the knob for CD and tune that. See the picture below, it's my DVD-ROM.
The attachment knobs.png is no longer available
Reply 4 of 16, by _StIwY_
GunKneeNeon wrote on 2023-06-01, 15:58:
@_StIwY_
So, looks like i was adjusting the wrong knob. The knobs for DVD - CD are these
Reply 5 of 16, by _StIwY_
......but i was adjusting only this knob, at this point i don't know what's this knob is for ?
Reply 7 of 16, by _StIwY_
GunKneeNeon wrote on 2023-06-02, 15:42:
_StIwY_ wrote on 2023-06-02, 09:23:
This is simply a screw.
Oh......all right xD.
So....after multiple tests there was no margin for improvements. It's been two hours, i rotated the knob a little clockwise....counterclockwise......a bit less.....a bit more.....nothing!! CD Speed 99 keeps failing at at all test.......the noisy laser head keep smashing forward and backwards in the rails as shown in the video
I assume there is no hope, right ?
.....but......check this out
i'm testing another Pioneer ( the DVD-105SZ ) which is basically the same model. It read CD-R flawlessy, but struggle....with DVDs and CD-RWs.
CD Speed 99 fails on "random seek" test. My patience is running out....
Reply 8 of 16, by GunKneeNeon
_StIwY_ wrote on 2023-06-02, 16:02:
What your laser head was doing is tracking, it couldn't locate the track successfully. As an end user what we can do is pretty limited. In a standalone CD/DVD player, there are more pots you can adjust, the focus gain/tracking gain/ef balance, most of which doesn't exist in a disc drive for computer use like yours. As for tuning the pots, it gets a little tricky sometimes, as a small amount of adjustment makes a huge difference. See this video for reference. This guy does it very well.
DO test the drive with commercial discs, as those recordable discs are difficult to read for older drives. Especially for CD-RWs, they are way more difficult to read even than CD-Rs. And you have to keep in mind, don't over do it, or you'll end up..... See the picture.
The attachment too much.jpg is no longer available
Reply 9 of 16, by _StIwY_
GunKneeNeon wrote on 2023-06-02, 19:42:
Yes but it bashes violently compared to the other one. So maybe it have problems on the alignment, or motors, or who knows where is the problem! At this point could be anything.
Anyway i tried almost any knobs configurations, and this one looks to have no hopes. The other one reads normal CD and CD-R, but does not read DVD anymore, maybe i turned the knob too much at some point and the laser got ruined. No matter what, if i put inside a DVD it ejects the disc in three seconds.
I guess it's time to throw them away 🙁
Reply 10 of 16, by wiretap
Replace any electrolytic capacitors in the drive first. That usually brings back drives that won't read disks reliably. The laser diode should not even need adjustment if you do that.
My Github
Circuit Board Repair Manuals
Reply 11 of 16, by _StIwY_
wiretap wrote on 2023-06-03, 10:58:
I give up. I don't have tools / skill to do such a thing. I could send these drives to someone if you want to. Contact me with a private message.
Reply 12 of 16, by ediflorianUS
try resetting the knobs/adjustment's back to previous settings , and cleaning entire inside with electronic contact cleaner. Learned the hard way that the rubber pulley ages badly and has problems eventually inside drives that use it mainly.
Or if you say only DVD problems , it may need a firmware upgrade/downgrade/reflash.... test also on virtualized os with specific drive drivers.(may be relevant).
My 80486-S i66 Project
Reply 13 of 16, by dulu
I have a similar problem, but it occurs more sporadically, in general the drive slows down but is fully usable. In case the drive stops working, I have an idea. Maybe it is possible to transfer the head from a no-slot-in drive from the same period? For example, Pioneer DVD-114. These drives can be bought for pennies, swapping the head is very simple, and you can bring a nice slot-in back to life
Reply 14 of 16, by ediflorianUS
dulu wrote on 2024-05-09, 20:09:
you can try , no guaranty success... however the settings may be firmware coded so it may not even recognize the new head.
Reply 15 of 16, by dulu
The attached photos show the laser of the DVD-104S drive. After a long search, I see that the laser that should mechanically fit (I can only confirm it based on the photos) is marked VNP1713. For $25 I would risk buying it, but one thing worries me.
https://pl.aliexpress.com/item/10050054313401 … 7Cquery_from%3A
Some of the lasers on auction websites do not have the SOP-10 chip. I don't know what it is. Could it be something like BIOS?
Reply 16 of 16, by dulu
I had the opportunity to buy another (no slot-in) Pioneer drive from the same period locally, but it turned out that the seller had a completely different drive, and he lost the other one.
I bought a VNP1713 laser on AliExpress, which is very similar, but unfortunately - it has a 24-pin connector. DVD-104S has 26 pins.
By the way, the laser model in DVD-104S is VNP1704. I didn't notice it before, the marking is very small and written on the laser PCB. After searching for the laser model in Google, there are no results.
If I get a no-slot-in drive from a similar period (for example DVD-114), I will share my observations whether replacement is possible.
