First post, by fsinan
System:
Cyrix 5x86-100
LS-486E Sis Chipset
16MB EDO
Cards:
S3VirgeDX-2MB
CL GD5540-1MB
Trident9680-1MB
S3Trio64V2-2MB
Quake Demo 320x240 Result:
S3 Virge/DX 11.5 fps
CL GD5540 11.1 fps
Trident 8900 11.2 fps
S3Trio64V2 12.5 fps
Thats all.
System:1
Cyrix 5x86-120GP & X5-160ADZ
Lucky Star LS-486E
System:2
Intel DX4-WB & AMDDX4-120
PcChips M912 V1.7
System:3
AMD K6-2-475 & Cyrix 6x86MX PR-233
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 1 of 16, by douglar
If I had to guess, I'd say that 3 of the 4 cards are PCI. Is that correct?
Reply 2 of 16, by fsinan
douglar wrote on 2024-05-22, 12:32:
All are PCI of course.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 3 of 16, by douglar
fsinan wrote on 2024-05-22, 12:53:
You have a PCI version of a trident 8900? Fascinating. I thought the oldest trident on PCI was the 94xx series.
Can you share a picture?
Reply 4 of 16, by theelf
fsinan wrote on 2024-05-22, 09:00:
System: Cyrix 5x86-100 LS-486E Sis Chipset 16MB EDO […]
System:
Cyrix 5x86-100
LS-486E Sis Chipset
16MB EDO
Cards:
S3VirgeDX-2MB
CL GD5540-1MB
Trident8900-1MB
S3Trio64V2-2MB
Quake Demo 640x480 Result:
CL GD5540 11.1 fps
S3Trio64V2 12.5 fps
Thats all.
No PCI 8900 for sure
What test did you do? timedemo X? screen size, etc i dont remember now, but in my cx586 120 i get maybe 4-5fps in 640
Reply 5 of 16, by The Serpent Rider
10+ fps on 640x480 resolution? Yeah, seems a bit too unrealistic for such setup.
Reply 6 of 16, by rasz_pl
Looks like standard 320x200 Cyrix framerate https://thandor.net/object/170
Reply 7 of 16, by fsinan
douglar wrote on 2024-05-22, 20:28:
Sorry my mind played a game to me it is 9680.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 8 of 16, by fsinan
The Serpent Rider wrote on 2024-05-23, 05:06:
It is 320x240. Sorry, I was tired.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 9 of 16, by fsinan
theelf wrote on 2024-05-22, 21:24:
System:
Cyrix 5x86-100
LS-486E Sis Chipset
16MB EDO
Cards:
S3VirgeDX-2MB
CL GD5540-1MB
Trident8900-1MB
S3Trio64V2-2MB
CL GD5540 11.1 fps
S3Trio64V2 12.5 fps
Thats all.
320x240, timedemo. I made a mistake.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 10 of 16, by rasz_pl
ISA trident would make no difference here, CPU is heavily bottlenecking.
Reply 11 of 16, by theelf
fsinan wrote on 2024-05-23, 06:54:
System:
Cyrix 5x86-100
LS-486E Sis Chipset
16MB EDO
Cards:
S3VirgeDX-2MB
CL GD5540-1MB
Trident8900-1MB
S3Trio64V2-2MB
CL GD5540 11.1 fps
S3Trio64V2 12.5 fps
Thats all.
Hi! i have a cx586 100mhz, overlclock to 120mhz, virge DX, and i get 14.6 at 320x240 timedemo, more or less same as you
rasz_pl wrote on 2024-05-23, 08:56:
Oh yes, Quake benchmark with ISA card is like one digit frame in 5x86 even with ISA at 10+mhz, PCI/VLB make a BIG difference!
Reply 12 of 16, by douglar
theelf wrote on 2024-05-23, 09:11:
Probably because the CPU can’t do game math when it is pushing pixels, so a slow video card reduces available CPU time, making the CPU bottleneck worse.
Reply 14 of 16, by douglar
rasz_pl wrote on 2024-05-23, 10:31:
10fps at 320x200 is only 640KB to be transferred every second
OK, lets go with 640KB second, assuming no pixels get written more than once.
  • An ISA Trident 8900C card will accept data at about 1.4MB/s, so pixel pushing is going to take up almost 45% of that second.
  • The fastest ISA VGA cards of can received data at maybe 3MB/s, so pixel pushing is going to take a little more that 20% of that second.
  • The average 33MHz PCI video card at the time could receive data > 10MB/s with efficient coding (not VESA BIOS calls) , so you are looking at ~5% of each second spent by the CPU moving data over the PCI bus.
So the simple calculation suggests that switching to the ISA bus from PCI bus is going to cause a 15% to 30% drop in available CPU cycles which would explain why those 11-14 FPS values for PCI video cards change into the single digit range with ISA cards. I'm doing my percentages wrong by a little bit, but you get the idea. If we were going for full accuracy, this is to be a differential equation, because as the frame rates fall, less data needs to get moved, but I'm not up for that this morning.
Reply 15 of 16, by rasz_pl
isnt 8900C the fast one? https://thandor.net/benchmark/33 hmm no, that would be 8900D. Still the difference to PCI is only ~30%
Reply 16 of 16, by douglar
rasz_pl wrote on 2024-05-23, 14:45:
30% difference at 10FPS. It gets worse as the FPS increases.
On a slow ISA card, 100% of your CPU is consumed pushing pixels at about 25FPS.
On a fast ISA card, 100% of your CPU is consumed at about 45FPS, regardless of your CPU, if you are drawing a full screen.
Doom and Wolf3d do some tricks to not redraw unmoving borders, so the actual amount of data getting moved is a little lower, and it's why frame rates increase when the borders get wider.
