First post, by GigAHerZ
I recently got this card and it seems to be absolutely amazing card.
It's basically the very compatible (and even enhanced kind of) ESS sound card that has built-in E-Wave waveblaster.
But as i have very little experience with any "external synthesizer" concept, i have few questions.
In dos games, when i choose Sound Blaster / Ad Lib, i should be getting ESFM sound, correct?
But when i choose General Midi with 330 address, i should be getting the sound out of that ES692S chip, correct?
I know that General Midi can be chosen without any wavetable additions. So is there a possibility for me to do General Midi with the ESFM synthesizer?
Any other "alternative options" that i should be aware of?
Also, what could those J12 pins be? If there's something even slightly useful to populate with components, i would like to do that. 😀
Reply 1 of 5, by dominusprog
GigAHerZ wrote on 2024-05-25, 14:17:
In dos games, when i choose Sound Blaster / Ad Lib, i should be getting ESFM sound, correct? But when i choose General Midi with […]
Yes and yes. What do you mean by using GM with FM synthesizer? GM uses the sound font stored in the ROM chip.
Reply 2 of 5, by GigAHerZ
dominusprog wrote on 2024-05-25, 15:46:
I vaguely remember from long times ago that if you have a simple sound blaster (or compatible) that does Adlib, then in games setup you could choose "General MIDI" and you get a different variant of FM synth. I might be misremembering, though...
Reply 3 of 5, by Grzyb
"General MIDI" doesn't specify any particular type of synthesis.
Yes, in practice that setting is used to operate a sample-based (a.k.a. wavetable) synth, connected via one of the following:
- external MIDI port
- internal Wave Blaster header
- integrated on the card
But!
It's perfectly possible to make an FM synth with MIDI interface + General MIDI instrument mapping.
I've never seen such a thing, but we all know that absence of evidence is not evidence of absence...
It's even possible to make a MIDI + General MIDI thing that doesn't use any synthesis!
Imagine an orchestra of robots playing on acoustic instruments...
Reply 4 of 5, by Grzyb
That may be for connecting VOLUME UP/VOLUME DOWN/MUTE buttons.
Reply 5 of 5, by mockingbird
Has anyone gotten the PCSPKR input to work? I populated J6 with a two-pin header as well as R39 with a 10K resistor yet I hear no sound (ESSVOL set to "/P:7").
Perhaps this feature was broken on this revision of the ES1869 (it does work in the later revision of the chip)...
EDIT:
I found the issue. Pin 53 (PCSPKO) goes to C57 which is unpopulated. It seems I need C56, C57, and R40, R41, R42. Anyone knows what the values should be?
The attachment es1869.jpg is no longer available
EDIT 2:
The datasheet has the necessary info:
C57: 0.1 μF
C56: 0.01 μF
R40: 470 Ω
R41: 220 kΩ
R42: 220 kΩ
I will populate the footprints and report back.
(Decommissioned:)
