Video stutter and shadow ram (Dos 6.20)
Reply 20 of 21, by vstrakh
ux-3 wrote on 2024-05-25, 19:35:
OK, but how do I write these disk images? I do have an USB floppy drive and am on Win 11.
Most of the times the DOS software could be copied from floppies into HDD folder, and setup ran from HDD.
Far Manager can 'enter' these .img floppy images, same way it does for .zip archives. You can copy files out of .img and put into target hdd/CF as you like without creating floppies.
Reply 21 of 21, by ux-3
kingcake wrote on 2024-05-25, 18:54:
the included manifest program will tell us much more about your memory map and the speed of you memory regions in the map.
I got it installed. Manifest is a programm in windows, right?
How do I find the speed of the regions?
Retro PC warning: The things you own end up owning you.
