First post, by winuser3162
is it possible to overclock something like a sound card, network card, power supply or any other part that isnt typially overclocked? id think overclocking a power supply would lead to blown caps or a fire.
1. Silicon Graphics octane, 2GB memory, MXE graphics board, 2 350MHZ R12K
2. Silicon graphics indigo 2, extreme graphics board, 198MB memory, 200 MHZ R4K
Reply 2 of 9, by Grzyb
Overclocking ISA bus affects all cards, and yes - disk controllers and NICs can get faster this way.
Also, does using an MFM HDD with RLL controller count as overclocking?
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 3 of 9, by darry
I'm going from distant memory here, but AFAICR, on the sound card front :
- it was apparently possible to overclock the DSP on at least some MWAVE variant based sound cards
- Some SB Pro compatible cards apparently allow one to set an effective sampling rate of more than 22KHz in stereo mode (specific software is required). YMF724 based cards may be capable of this
- Either the GUS Max or Interwave based cards (or both) could be set to more than 48KHz (64KHz possibly). I don't recall whether the low pass filter actually negated the potential usefulness of that
Anyone who remembers more/better, please correct me or corroborate, as needed.
Reply 4 of 9, by bakemono
I accidentally overclocked a YM2203 to 7MHz one time. The sound played an octave too high. I over-volted a fan once or twice. And to really stretch the concept, I 'overclocked' a furnace by replacing the drive pulley on the blower with one of smaller diameter so it would run at a higher RPM...
Wreckage reimagined on itch: https://90soft90.itch.io/wreckage-dash
Reply 5 of 9, by Babasha
PCI IDE cache controller by Tekram DC-690CD
Need help? Begin with photo and model of your hardware 😉
Reply 6 of 9, by Grzyb
Another example of unusual overclocking would be a Hercules clone graphics card.
BUT!
The goal wasn't to make it faster.
The goal was to make it compatible with SVGA monitors.
Normally, such cards use 16 MHz pixel clock, which produces 18 kHz HSYNC and 50 Hz VSYNC.
SVGA monitors need 30+ kHz HSYNC.
The solution is obvious: replace the 16 MHz crystal with something faster.
Sometimes it works, sometimes doesn't - I guess it depends of the memory speed.
Also, it's necessary to add a very simple DAC between the card and monitor, to convert 2-bit TTL to analog 0.7 V.
Reply 7 of 9, by Standard Def Steve
My Sega Mega Drive is overclocked. Getting a sweet 10 MHz outta that baby!
Way back in the day, I overclocked my Palm Pilot - think it was a III or a IIIx. Got a sweet 25 MHz outta that baby!
"A little sign-in here, a touch of WiFi there..."
Reply 8 of 9, by EduBat
Just a funny idea, please don't take me seriously: how about under-clocking the RTC and/or the PIT to get a boost on all the benchmarks that depend on them to measure time?
Reply 9 of 9, by Grzyb
EduBat wrote on 2024-06-04, 20:58:
I think sombody actually did that... not sure... some disk controller with BIOS slowing down the clock while disk operations?
Anyway, there was plenty of tricks to cheat common benchmarks.
