First post, by Brondahl
Hiya, I'm trying to organise it so that amongst the things DOSBox does automatically on start up is to launch the keyboard mapper.
So my question is:
EITHER: how can you edit the end of the config file so that it 'presses Ctrl+F1' rather than printing C-t-r-l---F-1.
OR What command can you write to launch the mapper.
I had a look in the readme, and it said you could:
... start the DOSBox mapper (either with CTRL-F1 or -startmapper as
a command line argument to the DOSBox executable) you ...
I've tried typing in "startmapper", "-startmapper", "startmapper.exe" & "-startmapper.exe" into DOSBox in the Z:\> and the D:\> drives but every time in returns:
Invalid command: #######
####### = what ever I wrote.
I've not had DOSBox Long, and I don't know enough to know what DOSBox executable means, but I assumed meant the main screen where you can type stuff.
Thank you for any suggestions.
