Reply 20 of 52, by Ozzuneoj
- l33t
Anonymous Coward wrote on 2024-05-29, 01:11:At least we know it belongs to another VOGONS member. I just can't believe you didn't dump the ROM yourself.
I presume you must have played with it before you re-sold it? Did you try the DX4 on it? And if so, did the BIOS report it correctly?
The board was completely non-functional, so he was giving it away, and I am trying to revive it currently.
I have tried several things so far, reflowed some bent legs on the back of the cache and BIOS sockets that looked to have separated from the solder pad, tried running with different sets of cache chips and tried swapping the keyboard controller (had this revive a different 486 board a while back) among other things.
So far, my POST card has shown no codes at all with the original BIOS installed, however, if I drop in some other unrelated 486 AMI BIOS chip I am able to get a POST code of 02 (hard to say what it means... possibly BIOS checksum or CPU related). I am trying it with an Intel DX2 66, which may not be compatible with whatever old 486 BIOS I've been using for testing. So there's a chance the original BIOS is the problem... which is actually unfortunate since that seems to be very hard to find.
I notice that the listing you posted above had two boards sold and the board I have now (that was pshipkov's) is definitely the exact board in the picture, so is there any chance another VOGONS user ended up with the second one? If so, it'd be awesome if they could dump the BIOS and post it here.
Anyway, I was able to dump the BIOS using my TL866A and it does have some readable data in it (similar to the older BIOS posted in this thread), but I have no idea if there is any corruption. If you want to try it on your board, please let me know if it works. If it does, then my board may have some other issue.
In the meantime, I am trying to find another BIOS chip I can flash the older version to just to see if I can get this thing to POST.
EDIT: Tried flashing the Dolch BIOS posted earlier to a different chip and using that in my board but it also does nothing. No POST codes, no beeps.
The POST card is showing that all voltages are present, including -5v, so that's a good sign... but this is a tough one to track down, for sure.
Have also tried a DX2 50Mhz, different RAM and 3 different keyboard controllers.
It's too bad, there doesn't seem to be any listed jumper setting to entirely disable cache on the board (other than switching turbo off), so I can't be 100% certain that it isn't an issue with a cache chip or socket.
Oh, and I did install an unused RTC for testing.
