Reply 100 of 111, by DoutorHouse
- Member
ssokolow wrote on 2024-05-30, 23:12:DoutorHouse wrote on 2024-05-30, 22:57:Thank you again so much for taking time to test it! I went and tried a different smaller mp3 and had the same crash.
Then, having ran out of ideas, I decided to apply the same bios version you have (1.01). Mine was 1.03 but it applied without any issues. I checked on BIOS settings and the MAC address is now all zeros (not sure if it's normal) but entered windows, and tried those mp3s again. Surprise: no errors whatsoever!!! I guess this later 1.03 Bios has some kind of error (i checked and it says it adds support for a new microprocessor.... I'm gonna run a few more tests...Here are both bios, in case you wanna test that wonky 1.03 😜
*facepalm* If newer audio drivers are not necessarily less buggy, I should have considered that maybe the BIOS could be the same.
I'll save copies of those files in case I wind up with another t5530 that needs to be downgraded.
Ahah, was thinking about that! Maybe the newer audio drivers will break media player again! Need to try that! 😀
Good news is that, apparently, the t5530 doesn't even need any of those VIA 4in1 drivers or the 5.24a hyperion one, let alone that 245682US8.exe fix for the IDE channels controller. I'll keep it for the t5710 where it seems it really is needed.
Thanks again for your help! If i hadn't noticed you had a different BIOS version, i probably would never think of downgrading it (with 1.03 windows said it had 94% of free resources, with 1.01 always says 84 or 86%... weird!!!!). 😜
