Reply 920 of 2029, by jakfish
@polpo Thank for your quick, helpful response regarding the configuration of the Femto/Pico/Pocket-386.
And I much appreciate the information that configuration should be within pgusinit and not MicroPython; I would not have known that.
I already use MBrutman's MTCP with my serial-to-wifi adapter and a Ominbook, 200LX, etc, so I'm hoping to edit the mtcp.cfg for the Pocket 386.
Regarding the NE2000 packet driver, is that simply a case of downloading the appropriate *.com and putting that in the c:\MTCP directory, the way that oldnet uses the ETHERSL.COM for its serial-to-wifi?
Reply 921 of 2029, by appiah4
polpo wrote on 2024-05-30, 20:44:
appiah4 wrote on 2024-05-30, 12:23:
pyrogx wrote on 2024-05-30, 12:09:
I have a bit of an odd question: Is the PicoGUS compatible with Linux? Especially some older versions from, like from 25 years ago. I know that there was quite extensive support for the GUS back then, including MIDI and patch loading, etc.
I don't think there is a compiled binary of pgusinit for linux, and I don't know if that is possible, but now I'm also curious.. Presumably if the PicoGUS could be initialized under linux then the GUS kernel modules would work..
The card doesn't need to be initialized with pgusinit if it's using the default port of 240h. Linux would be interesting to try out, especially since the Linux Ultra Sound Project drivers are what evolved into ALSA. I remember those drivers being really good back in the 90s on my GUS.
I might build a second 1.1 just to drop it into my test bench and install Linux on a cf-card for this experiment 😀 If you are really interested in hearing about this and maybe developing further tools for linux, I'd be willing to invest the time 😀 I was pretty excited to help with testing the 1.1 with games and contribute somehow.
Reply 922 of 2029, by Shreddoc
appiah4 wrote on 2024-05-30, 06:59:
Thanks a lot @Shreddoc, it looks like building a 1.2 card will be a lot of new expense and I'm not sure how much I really need the USB device capabilities, so I'll just build a second 1.1 with the PCB and components I already have..
If the 1.1 is working great for your system(s), then that is probably all that you need, especially if cost is a concern. The core functionality is the same.
My main motivation to build 1.2's is just for the fun of making, and also for the various small improvements such as reset stability and better physical fit.
If you already have all the 1.1 components, then - AFAIK - the only things you really *need* for building 1.2 instead, is new C1,C2,R1,R2,R3,R4,R5,R6,U10. Also there is a C11 now, which means 8 x 0.1uF caps, rather than the 1.1's 7 x.
And PCB, of course.
Reply 923 of 2029, by keenerb
Will this potential ne2000 support work on 2.0 boards?
Reply 924 of 2029, by Shreddoc
keenerb wrote on 2024-06-01, 00:05:
The 2.0 boards do not contain any wifi hardware.
That said, it's not out-of-the-question that creativity may find some alternative way, if one exists.
Reply 925 of 2029, by scroeffie
iam doing something wrong iam not getting any sound
Reply 926 of 2029, by SScorpio
scroeffie wrote on 2024-06-01, 15:53:
Show a directory list of C:\Ultrasnd, as well as the game you are trying to play's sound config.
Reply 927 of 2029, by scroeffie
i got it working but audio is very low i have to turn the speaker all the way up .how do i set the volume of the soundcard higher is there a program i need to run ?
Reply 928 of 2029, by Shreddoc
scroeffie wrote on 2024-06-01, 16:46:
The PicoGUS's audio output is a standard line level output, and is normally connected to the Line In of an external amplifier or powered speakers.
It is not intended to directly plug headphones or unpowered speakers.
Reply 929 of 2029, by scroeffie
Shreddoc wrote on 2024-06-01, 20:44:
iam using retro speakers self powered with a build in amp i need to turn the audio all the way up to hear something
so there is no program to adjust the audio levels ?
Reply 930 of 2029, by scroeffie
iam talking in dutch because i send the video to a friend who also bought one he has the same problem ,but i have to turn the audio all the way up on the speaker
https://www.youtube.com/watch?v=Vp8at8pslS0
Reply 931 of 2029, by digistorm
I think the PicoGUS has a slightly lower output then say a Sound Blaster (even in line level mode). I have it connected to the line-in of my AWE64 and I have to crank the input all up to make it audible. If I connect the PicoGUS directly to my mixer I have to increase the gain quite a lot to reach the same level. I think it is "normal", maybe old PC cards had a higher output level or different amps.
Reply 932 of 2029, by scroeffie
wil test tomorrow with difrent speakers maybe its my speakers
Reply 933 of 2029, by scroeffie
someone on discords says its normal just like a real gus card
Reply 934 of 2029, by terryfi
I just started using PicoGus, tried sound blaster mode with Prince of Persia, noticed the Intro is missing some notes/instruments.
Tried another motherboard and also playing OPL2 VGZ capture, same problem. I attached recording of PicoGUS and VGZ to this post.
I also notice some weirdness in Monkey Island 2, in carpenter shop you don't hear the saw instrument. My guess the OPL emulator is limited in terms of number of effects/instruments/channels.
Reply 935 of 2029, by MadMac_5
Just a quick note to say that using the PicoGUS as a MPU-401 card with an AWE 64 is a brilliant audio solution for late 90s DOS gaming. Last night I played Descent and TIE Fighter and it sounded spectacular hearing TIE Fighter with the X2GS and higher quality audio; before I'd need to use my Vortex 2 in SB Pro mode to be able to get glitch-free music since my SB 16 and AWE cards have massive issues with the iMUSE implementation that TIE Fighter uses.
Reply 936 of 2029, by pyrogx
appiah4 wrote on 2024-05-31, 07:05:
It was a bit of effort, but I managed to get the PicoGUS to run under Linux. I chose an old Slackware Linux 11 which has a 2.4 kernel, for my experiments. Initially I tried the builtin OSS driver. It detected the card fine at 0x240, IRQ5, DMA3 (no pgusinit necessary as polpo said) and I got a mixer, dsp and sequencer device. PCM playback worked, MIDI as well (after installing the proper patchset and using playmidi 2.4). Trying to use the sequencer as a MOD player didn't work.
So I grabbed a copy of the "Linux Ultra Sound Project" driver, ported it to the 2.4 kernel (This was actually the hardest part!), and with that one, it just worked:
The attachment screenshot.jpg is no longer available
/dev/gusinfo gave me:
Driver Version 3.0, Copyright (c) 1994-97 by Jaroslav Kysela (Perex soft)
Compiled in May 30 2024 for kernel 2.4.37.12-i486-generic (SMP).
Compiled with support for GUS Classic, DB16, Extreme, MAX, PnP soundcards.
Driver using 19 pages (77824 bytes) of kernel memory for data.
CARD #1-1 (gus):
>> Gravis UltraSound 2.4 (1024k) at 0x240, irq 7, dma 3
DMA:
used : 0
buffer ptr : 0xc0300000
buffer size : 65536 (real 65536, requested 65536/65536)
lock status :
owner : <NULL>
old owner : <NULL>
Interrupts:
TOTAL : 8345
GF1:
flags : daemon
record overfw : 0
UltraClick elimination defaults:
smooth pan : enable
full range pan: disable
volume ramp : 30
TIMERS:
owner : <NULL>
enabled :
timer1 value : 63
timer2 value : 1
base : 166
tempo : 60 (5020us)
effects ticks : 2
PCM [GF1]:
realtime buffering : off
playback underflow : 0
record overflow : 0
PCM [<NULL>]:
record overflow : 0
OSS SEQUENCER:
Mode : none
Card #0 (gus):
00: GUS MIDI interface
01: Gravis UltraSound
02: GUS MIDI emulation
>>: D0 -> D2 swap : disable
So, PicoGUS is indeed Linux compatible, at least with some ancient Linux version.
Reply 937 of 2029, by keenerb
MadMac_5 wrote on 2024-06-02, 14:33:
I think this is my primary use for the PicoGUS: Modern USB controller and MPU401 card.
Did you configure the PicoGUS on IRQ2 like a real MPU-401? Does it work out of the box as intelligent MPU401?
Reply 938 of 2029, by Pickle
keenerb wrote on 2024-06-02, 19:29:
yes it does and when paired with mt32-pi wavetable it becomes a builtin mt32 (or fluidsynth)
Reply 939 of 2029, by MadMac_5
I only specified the port as 340 when running pgusinit with /p 340, but within Windows I actually assigned the MPU-401 device as having IRQ 10. It seems to work in Windows and DOS without any issues in the games I have tried so far (Descent 2 and TIE Fighter Collector's CD), but I can't say for sure which IRQ it's using in DOS.
