First post, by zuldan
Recently came across this board. Unfortunately, it doesn't post. Any suggestions are greatly welcomed! I've ordered an oscilloscope which should be arriving next week.
The attachment IMG_5315.JPG is no longer available
Symtons;
- Motherboard powers on as soon as the board has power from the ATX
- CPU is stone cold (tried multiple, working CPU's)
- No beeps from PC speaker
- Motherboard sits in constant "reset" state
The attachment IMG_5316.JPG is no longer available
I've done the following so far;
- Reflashed the BIOS
- Tested random voltage regulators. All appear to be ok. Getting 12v, 5v, 3.3v, 1.5v
- Used deox on CPU socket
- No shorts detected
- Thermal camera not showing anything unusual
- Checked all the fuses (all ranged from 30 to 40 ohms)
- Capacitors around VRM tested ok with a ESR meter
- Tested SIO draw (OK)
The attachment IMG_5314.JPG is no longer available
Reply 1 of 21, by Nexxen
Close to 4-pin header, check the sop-8.
Maybe it's nothing.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 2 of 21, by zuldan
Nexxen wrote on 2024-06-02, 00:41:
Maybe it's nothing.
Do you mean the 4 pin header near the molex connector?
Reply 3 of 21, by zuldan
I removed the heatsink over the VRM mosfets.
The high side is showing 12v and the low side is showing 0v (it should be 1.5v). Hmmm
The attachment VRM.jpg is no longer available
Reply 4 of 21, by PC Hoarder Patrol
zuldan wrote on 2024-06-02, 01:51:
If those (brown) caps are UCC KZG series then possibly one or more 'silent' failures on their part!
Reply 5 of 21, by Karbist
zuldan wrote on 2024-06-02, 00:34:
This is not good, it means dead chipset most of the time, there's a big inductor close to the chipset, measure its resistance to the ground.
also meassure the resistance of this mosfet to the ground where I have pointed the arrow :
The attachment SB3.3v.jpg is no longer available
The vcore enable signal comes directly from the chipset and goes through this diode to the pwm IC,
you should have atleast 3v on both side of the diode:
The attachment Vcore.EN.JPG is no longer available
it looks like someone has changed the chipset heatsink, the original one has a fan in it, I wouldn't be surprised if the chipset was cooked to dead.
Reply 6 of 21, by Nexxen
zuldan wrote on 2024-06-02, 01:04:
Maybe it's nothing.
Yes. There is a little sop-8 chip. Look what it is and maybe it is connected to mosfets.
Just a guess. Maybe it's nothing at all.
Tha fact it powers on immediately means to me that the circuit responsible is broken.
There should be a driver chip for the mosfets.
Reply 7 of 21, by Nexxen
Karbist wrote on 2024-06-02, 09:10:
Can you give me the name of the big chip on the left of the arrow? That should be the driver.
Reply 8 of 21, by rasz_pl
boardview for deluxe 1.02, I think its same thing with just couple more components fitted
cold cpu = no Vcore as you later found out
Reply 9 of 21, by Nexxen
The SC2643VX provides a solution for microprocessor core voltage regulation
https://pdf1.alldatasheet.com/datasheet-pdf/v … 2643VXTSTR.html
8 pin ic:
https://pdf1.alldatasheet.com/datasheet-pdf/v … ECH/SC1211.html
To me it's one of these two.
I can be wrong, unlike rasz_pl I'm not a pro.
The two sot-23 are BAT54C, pretty common.
Reply 10 of 21, by zuldan
PC Hoarder Patrol wrote on 2024-06-02, 02:09:
They are KZG caps but the ESR meter seems to be happy with them. I'll keep this in mind.
Reply 11 of 21, by zuldan
It measures 80 ohms
Here are the measurements. Did you get this location from the boardview file?
The attachment diode.jpg is no longer available
Reply 12 of 21, by zuldan
Mistake
Reply 13 of 21, by zuldan
Nexxen wrote on 2024-06-02, 10:44:
Under the microscope.
The attachment IMG_5328.JPG is no longer available
Reply 14 of 21, by zuldan
rasz_pl wrote on 2024-06-02, 12:41:
Thanks for that!
Any chance you have a boardview for a A8N32-SLI Deluxe?
Reply 15 of 21, by zuldan
Ok so the low side mosfet is connected to pin 7 of the chip. AGND, pin 18 is 35 ohms.
The attachment chipchip.jpg is no longer available
Reply 16 of 21, by Karbist
zuldan wrote on 2024-06-03, 06:36:
You forgot to measure the resistance of inductor close to the chipset to the ground.
you're missing the vcore enable signal, so either the nforce chipset is dead or has bad connections under it.
Reply 17 of 21, by zuldan
Karbist wrote on 2024-06-03, 07:32:
Sorry missed that one. It's 80 ohms.
I also removed the 3rd party heatsink and the chip looks toast. The surface surrounding the die has bubbles on it (can't see from the picture). Is there a way to tell for sure it's gone? I'm here to learn. I love doing this stuff 😀
The attachment badchip.png is no longer available
Reply 18 of 21, by Karbist
It looks like someone has used extreme heat to reflow the chip, although the chip internal resistance still looks good after that heat abuse, mine has dropped to 50 ohm.
at this point you need either to properly reball the chip or inject lots of flux under the chip and reflow it again and hope for the best.
Reply 19 of 21, by Nexxen
Karbist wrote on 2024-06-03, 09:36:
The NB popcorned?
