16mb disk space issue with 64gb SD-card
First post, by Ribbicipp
So i recently bought a 64gb SD-card that i want to use with my SD to IDE adapter for my old Pentium 1, 166mhz with a Socket 5 motherboard.
First off i use the software "Minitool partition wizard" to format the SD-card with FAT32 on my modern PC, so far so good.
Then when inserting the SD-card into my old Pentium 1 PC and booting it up, the amount of space on the card is recognized correctly as 58-ish gb, so far so good.
The problems start when i experiment with deleting the partition in fdisk/xfdisk in order to create a new primary partition with room left for an extended partition on the unallocated disk-space.
Whenever i delete the FAT32 58gb partition, there is basically just 16mb space free left. No partitions, just 16mb "free" of unallocated space.
I've been trying to create 2 partitions in Minitool partition wizard, one primary and one logical (no extended option exists). When doing this i can't even get into fdisk/xfdisk because it says that it cannot find the extended partition (ofc).
Been trying to format the SD-card into FAT16 with 4gb space. Works fine, but same problem again when trying to delete the partition and make a new one with an added extended partition, unallocated space is just 16mb.
What is going on and is there a solution to his? Im really stuck in an annoying loop here.
Reply 1 of 23, by dominusprog
64GiB is too large, use a 32GiB card instead.
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 4 of 23, by wierd_w
Which version of fdisk are you using?
Win98, win95, dos 6.22, freedos, or 'other'?
Reply 5 of 23, by douglar
Ribbicipp wrote on 2024-06-03, 16:55:
dominusprog wrote on 2024-06-03, 16:36:
why is 64gb an issue vs 32gb?
There are some BIOS that have issues if a storage device reports cylinders > 65535, which is what happens when a device has a capacity > 32GB (33.4 if you are doing base 10 GB). Your system seems like it is from a period when that could have been an issue.
What is the date on your motherboard BIOS? Is your BIOS configured for LBA or CHS addressing ?
And what version of DOS are you using? You need to use Win98 DOS or Free DOS to see devices larger than 8.4GB.
https://www.vogonswiki.com/index.php/Storage# … age_Limitations
Reply 6 of 23, by Ribbicipp
wierd_w wrote on 2024-06-03, 18:10:
im using the version that came with the win98 bootdisk, so win98 i guess.
Reply 7 of 23, by Ribbicipp
douglar wrote on 2024-06-03, 18:38:
There are some BIOS that have issues if a storage device reports cylinders > 65535, which is what happens when a device has a c […]
My PC is an AST Advantage 623E and im running the latest bios for it, namely version "05576035.exe Advantage! 62x System BIOS 1.04 144193".
Im running the DOS version that comes with a win98 boot floppy, which is what im using when booting up the PC.
When entering the bios, i don't see any options for LBA or CHS. It's pretty barebones tbh. So even if i try to manually enter the heads, sectors etc for the SD, i can't get up to the numbers that i need in order to make it read over 503 or so mbytes.
But, like i said, when i format the SD from my modern PC with FAT32, the old AST PC recognizes that it's 58gb. It's just as soon as i delete the partition in fdisk/xfdisk that it only recognizes the unallocated space as 16mb free.
Reply 8 of 23, by Jo22
Generally speaking, DOS has a 1024 cylinder limit (usually counted as cylinder 0 to 1023).
MS-DOS 7.1 is LBA aware, yes, but then the drive geometry should be set up as LBA in CMOS and Extended int13h services should be available, too.
The FAT partition type should be LBA, too, I think.
"Fortunately, most OSs today can cope with hard drives with more than 1024 cylinders, or can use extended INT13 addressing.
The list of such OSs includes Windows 98.
If you have DOS on your system, you should ensure that its partitions fall entirely below the 1024-cylinder limit, just as do your bootable partitions.
Microsoft has introduced new partition types for partitions that fall partly or wholly above the 1024th cylinder,
but not all OSs understand these partition types, so if you use them, you might not be able to access these partitions from all your OSs."
Source: https://www.informit.com/articles/article.asp … 31238&seqNum=14
Edit: Old versions of GParted did support resizing of FAT32 partitions (older than 0.9.0).
Success report: How to resize a partition on Windows 98
Tools like Parted Magic or Hiren's Boot CD may help, too.
Reply 9 of 23, by douglar
Ribbicipp wrote on 2024-06-03, 19:06:
My PC is an AST Advantage 623E and im running the latest bios for it, namely version "05576035.exe Advantage! 62x System BIOS 1. […]
Even though it lets you enter large values, it really sounds like your BIOS isn't going to do > 528MB without some help. Consider making an EZdrive bootable floppy and installing drive overlay software: http://vogonsdrivers.com/getfile.php?fileid=1900
It will let your PC use LBA on your storage device in a way that is compatible with contemporary computers.
Reply 10 of 23, by Ribbicipp
douglar wrote on 2024-06-03, 20:57:
Cool, will try it out and get back if issues occur (which they probably will).
Thanks for the tip.
Reply 11 of 23, by jmarsh
This sounds like the usual sintechi SD->IDE adapter bug where it doesn't initialize properly if a FAT partition isn't found on the card.
Reply 12 of 23, by douglar
jmarsh wrote on 2024-06-04, 01:23:
I have not run into that issue. You have trouble making the first partition on an empty SD?
Reply 13 of 23, by jmarsh
douglar wrote on 2024-06-04, 03:01:
Creating the partition usually isn't the problem, it's whether it will stick around after a power-cycle... typically if it's not a FAT partition, it won't.
It boils down to the adapter overriding its emulated C/H/S values with ones from the FAT partition's BPB, for "compatibility" reasons. Except when it can't find a FAT partition, it freaks out and won't return any data except the drive identify response (until a write to sector 0 occurs).
Since OP is using a different machine to initially create the partitions, I would guess the CHS values being set in the partition are different from what the adapter defaults to but it "adopts" them from the partition... then it reverts back to the defaults when that partition goes away, which are different from what the BIOS expects. Wouldn't be a problem if the "golden rule" of only using the target PC to partition and format the drive was followed...
Reply 14 of 23, by douglar
jmarsh wrote on 2024-06-04, 11:44:
Creating the partition usually isn't the problem, it's whether it will stick around after a power-cycle... typically if it's not […]
I agree that the symptoms that the OP having would be caused if his contemporary computer is using LBA and the legacy is using one of the mid 1990's ECHS addressing schemes. They just don't access sectors in the same way.
EZ drive should let the vintage computer use the same addressing scheme as the contemporary one does and that should solve the problem. There are a bunch of other options besides EZ drive, like XTide Universal BIOS or Ontrack.
Reply 15 of 23, by jmarsh
XTIDE (from a ROM) may work but drive overlays would likely confuse the adapter because they replace sector 0.
Reply 16 of 23, by kingcake
jmarsh wrote on 2024-06-04, 16:01:
Never had an issue using Ontrack with SD or CF. In many situations overlays are better than XTIDE, especially on a faster machine with ram to spare.
Reply 17 of 23, by Jo22
Can't the BIOS be updated?
I remember there had been various patched versions at https://www.wimsbios.com/ and http://wims.rainbow-software.org/ and https://www.wimsbios.com/large-hdd-patched-bios.jsp
Reply 18 of 23, by dormcat
IIRC the AST Advantage! 600 series was not that old: while I couldn't find the exact spec of "623E", LGR had made a video about 622 last February, which had an 850MB HDD by default. Even the older Bravo series with 75MHz Pentium had minimum 850MB HDD. The BIOS of LGR's 622 was 1.02 and dated 1996 so Ribbicipp's 1.04 (assuming the same as TRW's) could only be newer and was the latest BIOS available for that MB.
The attachment AST_Advantage_622.jpg is no longer available
I'd suggest Ribbicipp start with the smallest SD card available, preferably starting with 2GB or less using FAT16, followed by 4-32GB using FAT32. A 1996 vintage MB is likely to hit the 8.4GB barrier.
Reply 19 of 23, by douglar
They work for me with a Sinitchi IDE-SD bridge.
