Reply 80 of 82, by davidrg
herman4 wrote on 2024-06-02, 23:59:download/file.php?id=66789&mode=view
Does anyone have info on how to connect all the wiring to make this one work? And who is the manufacturer of this case?
Do you have one of these cases/do you have more photos? I assume the case has two 3.5mm jacks on the back and you just run a cable from the line out jack on the sound card to the line in jack on the case, and from the microphone jack on the sound card to the microphone jack on the case.
At least that's how case #1 here works which I assume, given the visual similarities, is made by the same company. No idea who makes either though.
