First post, by GloriousCow
I'm happy to announce a new CPU Test Suite for the Intel 8088 CPU has been merged into Tom Harte's excellent ProcessorTests repository at https://github.com/TomHarte/ProcessorTests/tree/main/8088.
If you're unfamiliar with JSON CPU tests, I've written a short blog article with more information, which you may read here: https://martypc.blogspot.com/2023/09/a-test-s … intel-8088.html
This test suite is extensive - covering over 300 opcode forms, consisting of over 3 million individual tests spanning nearly 90 million cycles.
EDIT: We've reorganized things a bit, the 8088 test suite is now hosted at https://github.com/singleStepTests/8088
MartyPC: A cycle-accurate IBM PC/XT emulator | https://github.com/dbalsom/martypc
Reply 1 of 3, by GloriousCow
Version 1.1 was recently merged, no actual test changes but the test disassembly was updated.
I've been playing around with data mining the tests with Python. Here's an example of the sort of thing you can do, histograms of cycle execution time for all 8088 instructions:
warning: big image
The attachment 8088_timings_03.png is no longer available
Reply 2 of 3, by GloriousCow
I have uploaded a new version of the 8088 tests, V2.
  • 50% of included instructions now run from a full prefetch queue. This vastly improves visibility of actual cycle timings for short instructions that would otherwise be bus-limited. I even found a few off-by-one cycle errors in MartyPC.
  • The value of the 20-bit multiplexed bus is now included per-cycle, instead of presenting the "address latch". Various status flags are encoded on the bus pins during various t-states, so the information may be useful if you are developing pin-accurate emulation.
  • Fixed a bug in the V1 test generator that did not preserve the value of undefined flags from the CPU. I regret this error made V1 useless for researching or validating undefined flags. V2 should now be a valuable resource for researching undefined flag operation.
  • Switched CPUs from the Harris 80C88 to an AMD D8088 1982. There are tiny variances in behavior of the Harris 80C88 used previously. Unlikely to be of any particular concern to most.
Reply 3 of 3, by GloriousCow
A test suite for the 8086 is now available also. It offers little advantages over the 8088 set if you're just looking to validate instruction correctness, but those interested in cycle accuracy for the 8086 might find them useful as they capture per-cycle bus activity, including the 8086's BHE pin state.
https://github.com/SingleStepTests/8086
