First post, by Syntho
I have a P100 machine that was working fine last time I booted in a few months back. Now it starts up but there's no beep during POST and the video never starts. I replaced the battery, took out each component one by one and switched ram sticks in and out, even replaced the BIOS chip, and still it does the same thing. As a last resort I switched the CPU, and the old CPU did indeed have some broken and discolored pins on it, but the new one won't work either.
I think I'm going to try cleaning out the CPU socket with non-residue contact cleaner and compressed air. If that doesn't help, I'm out of ideas. What else would you try, and do you think it'll be worth it to get a POST test card? I see some for not very much on Amazon. Not sure which one to get though.
Reply 1 of 31, by kotel
You should get an POST card. Preferably the one with more components. There are some post on here about POST cards, although I don't remember them.
"I can believe I'm saying this, but...
Look alive people! Rest now and we die... Let's move."
- Aradus
Reply 2 of 31, by Rwolf
I'd look at the power supply and just run it with basic load (suitable hard disk for reference load perhaps, e.g. nothing connected to PSU except a dummy load for (usually) +5V to get voltage references right)
If that is ok, look for shorts on the motherboard - remove all unneeded loads, video card, ram etc. to check basic functionality.
e.g. a bios beep would only work when the cpu has test code to run so u need that - bad voltage regulators for cpu perhaps can be a problem. You could have a stuck reset signal keeping the cpu from doing anything useful. But you usually need some measuring tools.
Reply 3 of 31, by Syntho
I have a POST diagnostics card on the way as well as a little PSU tester that came with it.
In the meantime, I looked and saw a slightly bulging capacitor near the CPU. I noticed it a while back when I acquired the PC but it still worked fine. I desoldered it, hooked it up to my ESR meter, and it's definitely bad. I have a replacement on the way. I'll solder that in and let you guys know the results when I can test everything.
Reply 4 of 31, by kotel
Syntho wrote on 2024-06-06, 15:42:
Mind posting pics of the POST card?
- Aradus
Reply 5 of 31, by kingcake
edit: double post somehow
Reply 6 of 31, by kingcake
The first commandment of troubleshooting: Though shalt check voltages. (including voltage at the cpu socket)
After that, check the reset line.
After that, check the clock.
After that, check if the cpu is actually executing code
if all that is good, then you can start worrying about eliminating things like ram/cache/whatever you can unplug.
Reply 7 of 31, by gerry
i have a similar situation - a nice p4 system that i haven't run for a long time, ran it and:
first time started but screen was minimal res, seemed strange so i set in windows and then it crashed
restarted with endless beeps (usually memory or vid prob) and blank screen
re-seated components and restarted thinking the agp may not be seated properly - no beeps and no video, tried same with cell battery out and onboard vga - same result
minimised all - no ram, no cards, no disks, got three beeps (usually ram prob) and no screen
added one ram and back to no beeps and no screen
and then i noticed a very slightly bulged cap, so it might be that. the fact that the pc started but with problems, then crashed, then beeped then went completely silent suggests something long those lines. shame. now to weigh up time spend trying to solve against, well, not solving it
Reply 8 of 31, by Syntho
I've got a few tools here and there like a multimeter, oscilloscope, soldering iron etc, but I've never worked on or diagnosed a PC before. Is there a little tutorial somewhere that can guide me along for checking those things? I'll have the POST diag card and the new cap later today, so I'll update the thread when I get that done.
Reply 9 of 31, by wierd_w
In the case of failed capacitors, unless there are some obviously exploded tantalum ones near the bus slots, the ones you are looking for are barrel shaped metal cans.
You want to check them for orange or brown "Goo" around the top of the vent, on the legs, underneath the can, OR-- for peaked, bulged tops near the little creases in the metal up there. Those are all very clear signs that the capacitor has failed.
Signs of failed capacitors in terms of a working system, are things like spurrious reboots, random but persistent bluescreens/lockups, etc.
Reply 10 of 31, by Syntho
I replaced the cap. Didn't progress any further. Still no BEEP and not POST'ing. So I put in my POST diag card. It only gives me dashes on the error display, which I read somewhere else means that it can't even get to the point that enough code is run to give me a code on the POST card.
When I took out the CPU in this machine, it had multiple broken pins. I think that CPU was just abused a little by whoever had it before I did. I put in a brand new P133 CPU but it's still giving me the same issue. And before I put it in, I went in there with non-residue contact cleaner and compressed air and blew out the socket very well. I'm thinking maybe something is wrong with the socket or something.
You guys have any more ideas?
Reply 11 of 31, by kotel
Can you post specs of that pc? And pictures of the board would be very nice too.
- Aradus
Reply 12 of 31, by Syntho
I'll take a pic and post tomorrow when I'm back home. Something I forgot to mention is that the POST card didn't have its 3.3v LED coming on. It had +12, -12 and +5 illuminated. I wonder if that had something to do with it.
You can see the card here: https://www.amazon.com/dp/B072QSQQKT?psc=1&re … product_details
And the motherboard here: https://theretroweb.com/motherboards/s/azza-5is
Reply 13 of 31, by kingcake
Syntho wrote on 2024-06-08, 23:23:
Those cards will light up for a WIDE voltage range. You need to check the voltages with a meter.
Reply 14 of 31, by Syntho
I'll be getting onto that in a few here. I wonder if the 3.3v LED not coming on is what the issue is. Does anyone know what the 3.3v rail feeds?
Reply 15 of 31, by kotel
As I remember BuB on yt done a video about slot 1 ASUS boards, which most of them had missing 3.3v. Turns out it was a de soldered mosfet near cpu slot on all of them.
- Aradus
Reply 17 of 31, by Syntho
Ok, according to this:
AEn0k_trtcNlsbG4NTDlkKpvh1Afu6om0j_sgHDQb1v6jW2lhBC7S0GaPd6nlxJo2GH28yChLBrl_Dfx_S1dJnq_0Vi3pyUV2RJWTcXo1MzonOd-3QnN7mjuQbgZ_OD74BmMEI9Si7wZMz8tIP7t=s0-d
There is no actual 3.3v rail. I tested the P8 and P9 connectors and both were as they should be.
Reply 18 of 31, by Rwolf
On old PC:s the +3.3V is generated by voltage regulators on the motherboard, usually close to the CPU.
Most chips were +5V back then, and I guess not much else used +3.3V; Super I/O chips I think did.
Reply 19 of 31, by cloppy007
Syntho wrote on 2024-06-09, 16:11:
Ok, according to this: […]
You're right. I've got 2 similar PCI/ISA post cards and one of them won't work in 5V-only PCI slots (nor ISA...). Have you...
  • Measured the VRM output? If your board has the VRM slot it will surely have 2-4 jumpers, you can get the CPU voltage from any of those. Otherwise it'll be in one of the leads of the transistor with a heatsink just next to the battery
  • Verified the BIOS chip? If you have access to a programmer, try reading the BIOS chip to see if it reads something or garbage.
  • Cleaned the cpu and bios sockets with IPA or contact cleaner?
