First post, by Cosmic
- Member
Would an FX5700 Ultra work in a typical 440BX board with an AGP 2x slot? TechPowerUp shows the card as AGP 8x though it's keyed for 3.3V and 1.5V. I've had no problems running an FX5200 or FX5500 in an Asus P2B-B, both of which are also listed as 8X cards with the same NV34 core, though they show up as "AGP 4x @ 2x" in GPU-Z. The biggest physical difference I can see is the 5700 requires external molex for power.
I know it's overkill for a P3 system, but I just wanted to play around with it, benchmark it, and make sure there's no issues before plugging it in for testing. Cheers :]
https://www.techpowerup.com/gpu-specs/geforce … -5700-ultra.c70
Rigs: Harris 286-16 [WIP] | Am386 DX-40 | i486 DX4-100 | MMX 233 | K6-III+ 600 | P!!!-S 1.3GHz | XP 3200+ 2.3GHz | Q6600 3.2GHz
