First post, by KT7AGuy
I'm about 20 years late to the game here. I recently finished Deus Ex and thoroughly enjoyed its use of 3D Positional Surround Sound while wearing headphones. (CMSS makes it even better.) To take advantage of this neat feature, your sound card must have an enabled onboard DD/DTS decoder and S/PDIF Passthrough must be disabled. 3rd-generation Sound Blaster Live cards (SB0220) and newer should have this. However, some OEM variants do not. OEM Audigy 2 ZS and X-Fi cards are notorious for lacking this feature.
I have just started playing Halo for the first time and noticed that it also supports this feature. Just set Hardware Acceleration to Yes and Sound Quality to High in the audio settings.
Are there any other games that also support this cool feature? I'd like to start a list of which games take advantage of this.
Reply 1 of 6, by Falcosoft
I do not think it's true in this form. 3D positional surround sound has nothing to do with the audio compression format (AC3/DTS etc.) it also works with uncompressed PCM data (what's more it's better). 3D positional audio with older games only requires DirectSound3D hardware acceleration (and EAX or A3D). On more modern Windows operating systems (Vista+) unfortunately DirectSound3D hardware acceleration has been removed so workarounds like Creative's Alchemy or Realtek 3DSoundback or Indirectsound is needed. There are countless older games using 3D positional audio through DirectSound3D/EAX/A3D/OpenAl.
https://en.wikipedia.org/wiki/List_of_games_with_EAX_support
Also here on Vogons there are many topics about 3D audio or the restoration of it on modern systems (even Deus-Ex specific):
Restoring surround sound to Deus Ex and other games - should I get Sound Blaster MB3?
IndirectSound:
indirect sound
Website, Facebook, Youtube
VST Midi Driver Midi Mapper
Reply 2 of 6, by tgod
You shouldn't need the dolby surround setting in deus ex since its for outputting a pro logic compatible format if your sound receiver supports it, nothing to do with DTS and dolby digital as those are simply digital compressed output formats. Since you were running it under XP the hardware sound acceleration is still available which CMSS can use for the HRTF. Though I believe dolby's own HRTF technology, dolby headphone, is suppose to be compatible with sound sources like pro logic, so if you were using that instead it would actually work.
Reply 3 of 6, by KT7AGuy
Thanks for the replies!
I'll have to go back and test this again, but I seem to recall the Deus Ex surround sound feature not working unless I also enabled the onboard decoder. When I get a chance, I'll test it and report back.
Reply 5 of 6, by KT7AGuy
Falconsoft, tgod,
I finally got around to testing Deus Ex again. You were both correct on this matter, so I wanted to acknowledge you and thank you for your comments.
DD/DTS onboard decoding settings had no effect whatsoever. What did have an effect was disabling "Hardware 3D Support" in the Deus Ex sound settings. Without that, it sounded just awful as your advice suggested it would.
My understanding of XP-era sound technologies is clearly lacking. I will do better in the future.
Reply 6 of 6, by KT7AGuy
This post is a correction and retraction.
Just in case anybody new encounters this thread, Phil had already documented and explained these features here:
https://forums.overclockers.com.au/threads/ho … dphones.844394/
https://web.archive.org/web/20180107090035/ht … dphones.844394/
Anything and everything I said previously regarding this topic should be disregarded; I did not fully understand what I was talking about. If you're looking for an official Sound Blaster or Creative source, you can find it here:
https://web.archive.org/web/20141124194356/ht … .aspx?sid=96663
