First post, by Achilles2
Dear All,
Just grabbed a couple of old computers (486 DX33 and a Pentium 166). I was about to test them today when I found that they don't have any ps2 ports, but rather
486 has 2 standard serial ports (one bigger than the other - not sure if it's a parallel port) for keyboard and mouse, while the other has a serial port + a rounded port for keyboard (DIN 5 - for which I already got a converter).
Can you please provide some advice on the best way to proceed? Add some cards to both computers to make them work with ps2? Have some sort of converter from os2/usb into serial ?
Thank you.
Reply 1 of 13, by Disruptor
Some of the later 486 computers (especially PCI ones) and Pentium computers are likely to have an internal PS/2 mouse port at least, so you just may need to find a bracket for it.
Reply 2 of 13, by Achilles2
Just found that one port is a DB-25 Serial/Com port and the other a DE-9 Serial RS232...
Reply 3 of 13, by Ensign Nemo
Sounds like you have an AT port on one of them, but you already have a converter. You could also try a serial mouse with that machine. I'm a bit confused about what you mean by two serial ports of different sizes. It might be useful to take a picture for us.
Reply 4 of 13, by jakethompson1
The big keyboard port is an AT keyboard port. It's electrically compatible with a PS/2 keyboard port, and all you need is a passive physical adapter to connect a PS/2 keyboard.
If there is no PS/2 mouse port, these systems were originally used with a serial mouse. So it's up to you to grab one, figure out what kind of conversion device you want to use, or as Disruptor said, check the motherboards and see if there is an internal PS/2 mouse port header to which you could wire up a port.
There's no way the 486 takes a keyboard on a serial port if it's a normal desktop PC. It should have an AT keyboard port just like your Pentium.
Reply 5 of 13, by Achilles2
You guys were right, seems I have an AT port in each of the computers for keyboard. I will buy a converter to PS2 and connect my PS2 keyboard there. Regarding mouse, are you aware if there's still any mouses around on sale using DB9? what sort of solutions are you using to connect your mouses to your DB9 ports?
Reply 6 of 13, by Achilles2
I got some db9 to ps2 converters in the meantime, hope they work! 😀
Reply 7 of 13, by Ensign Nemo
You could look for an old serial mouse or a kvm switch that converts ps/2 to serial.
Reply 8 of 13, by jakethompson1
Achilles2 wrote on 2024-06-17, 18:55:
They aren't made any more, but there are plenty on ebay including new old stock if you're willing to pay for one.
They are all ball mice. The only optical serial mice were the ones with a special mouse pad.
The issue is the serial port doesn't provide enough power for an optical mouse.
Reply 9 of 13, by AlessandroB
A converter like this should work or the conversion of the serial mouse need an active converter?
Reply 10 of 13, by jakethompson1
AlessandroB wrote on 2024-06-17, 20:56:
If you have a 90s PS/2 mouse that also can speak RS-232 through its connector (sometimes they will say that underneath), like one that came with a passive adapter for serial, it's possible that kind of adapter will work. But the pinout was not standardized. And you can't just grab a 2000s optical mouse and hook it up to that. It won't work.
Reply 11 of 13, by rasz_pl
Achilles2 wrote on 2024-06-17, 19:14:
they wont, require special old mice and those werent standardized even in same brand (ms had two wiring convention)
you need one of those PS/2 mouse to Serial Port adapter or similar projects
Reply 12 of 13, by Disruptor
They may work with mice that were designed for dual use RS-232 & PS/2 and should be considered as non-standardized custom adapters.
But basically that are ballpoint mice since RS-232 just allows a very low power consumption.
Reply 13 of 13, by dionb
Are you talking about passive adapters (like pic above) or active converters (things with a chip on/in them)?
The latter should definately work with basically anything that talks PS/2 protocol but the former will only work with mice that talk RS232 serial. Worst-case, given the higher voltage levels on serial vs PS/2, you might even cause damage to a PS/2-only mouse on a passive converter to serial.
For questions like this it's always useful to specify what hardware you bought, or at least give a link or pic for the item.
