First post, by thepirategamerboy12
I've noticed that mainly with older stuff, not much newer games, running on my Ryzen 9 5900x + RTX 2070 Super Windows 10 PC that when I launch them they start for a second and then keep minimizing on their own... over and over again until maybe if I keep clicking enough times where it eventually stops. I was just experiencing this again with Streets of SimCity and know UT99 does the same thing at the top of my head. Has anyone else had this problem? I tried looking it up myself and couldn't find anything that helped. Thanks.
Reply 2 of 2, by thepirategamerboy12
DosFreak wrote on 2024-06-18, 10:33:
Close things you have open in the system tray (may need to use task manager) until you have identified the culprit.
That worked, I figured out it was one of my driver control panel thingys causing it. Thanks, don't know how I didn't think of that myself.
