Reply 420 of 832, by PC@LIVE
- Oldbie
So, for tomorrow I plan to get to work on a few MB, I have a couple with BIOS chips to reprogram, for this purpose I got the Legacy adapter, without that I would not have been able to, but if the motherboard works again, it is not 100% safe, in any case I would be quite sure that if there is a problem, it must be somewhere else.
Of course, I will perform relatively simple jobs, because at the moment I do not have enough time ⏱, to verify in detail the various tensions, or any short (if any).
A job that I have already postponed for some time ⏱, is the repair of the pin of a cache chip, on the Soyo SY-5BT, this card even if it is not ASUS, it still has a certain affective value, I had the first version with an AMD K6-200, as the first socket 7, and I remember it quite valid for the times (mid-90s), unfortunately that first version does not support voltages lower than 2.8V, although it is possible to do some tests with jumpers, and maybe find undocumented settings, which give VCORE of about 2.5V, which would be a fairly tolerable voltage for AMD 2.2V K6-2.
As for me, I have the second revision of this board, which has an extra jumper, which allows the selection of VCORE from 2.1V - 2.2V, maybe even here you could do some tests by moving the jumpers, maybe finding the right combination you could go down to 2.0V, which would be ideal for K6-2+, or other similar low voltage.
As I said there is a missing pin from a cache chip, for this job, I got some mini cutters, which should allow me to remove a part of the plastic, and make sure that the missing pin is repaired, welding a bridge between MB and the chip.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
