Reply 20 of 25, by TMM
akimmet wrote on 2024-06-20, 18:44:So, if I understand correctly this project is essentially a SBC with a SCSI interface in target mode? So similar in idea to PiSCSI, except hopefully far faster than the RasberryPI gpio interface.
It would make sense to use FreeBSD, since it was one of the only open source operating systems that supported SCSI targets on a traditional SCSI bus.
It is good to hear you are doing better, and still able to work on this project. Life in general can always get in the way when you least expect it.
That is essentially what it is. But it has a real SCSI controller chip not a software emulated one!
