The 486-voltage-interposer for Intel- and AMD-486-CPUs is ready for use - see pictures.
Not all GND-pins are connected to the GND-Vout of the buck-generator (only few pins at one site), this seems to be enough.
About the buck-generator from this link shown above (https://www.conrad.de/de/p/az-delivery-lm2596 … ductDescription): POOR quality, I must say:
- 2 of 5 generators ordered with NO functional trimers (maybe they are defective, maybe bad soldered)
- the Vout-display of the working ones shows up to +/- 0,1 V than measured by myself (so better you don't trust the display)
- the solder-quality itself seems to be not good
Anyway, using one working buck-genereator, on the HOT-433 Rev. 4 shown above, it was possible to run STABLE an Intel 486DX4-100WB @ 133 MHz (FSB 66) and 4,25 V in Windows! Not bad 😀 The CPU was able to boot in DOS @ 150 MHz/4,8 V, but was completely unstable for Windows (BSOD at booting).
The rest of the hardware:
- 256 KB L2 @ 3-2-3
- one module of 32 MB EDO-RAM (50 ns)
- GeForce 2 MX-400
The results for 133 MHz:
- GLQuake (800x600): 24,5 FPS
- Quake II: 14,0 FPS
Until know I was not able to run some of my Am486DX5-133, which already runs @ 4 or 5 V at 180 MHz, at 200 MHz (not all testet yet). On the other hand, I found another such CPU, which can do 180 MHz at only 3,70 V (but nothing faster like this).
So in conclusion it's very useful to have such an interposer to find out the highest stable frequency of a 486-CPU.
I LOVE CPUs RUNNING IN [GonzoHz]
