Reply 53440 of 57461, by TheMobRules
iraito wrote on 2024-07-02, 20:01:I would never use those old ass original PSUs, first they barely deliver the right amount of voltage, second some of the components in them are so old that the voltage output is totally out of whack hence hurting the device.
I have 2 OG MT-32 old and new and i use new PSUs, filtered and with a higher amperage than needed, having more amps never ever hurts, it keeps the PSU cooler and power delivery more stable.
That's not correct, the original power bricks of Roland modules are very simple, consisting of a large transformer, rectifying diodes and a capacitor. This generates the 9VDC input voltage that doesn't need to be too precise since it is then regulated down to 5V by the 7805 inside the module, as luckybob explained above. It's a classic linear design, and even though it requires a huge transformer and is not very efficient, it should produce cleaner power than a switching power supply. By using a modern switching PSU you don't gain any noticeable advantages, you may be even introducing more noise than with the original.
Switching PSUs are used because of size and efficiency reasons, so for things that need like 100W or more of power they are the most logical solution. But for low power stuff like these Roland modules a simple linear PSU is as good (or maybe even better) than a switching one.
Note that I use the modern Roland switching adapters myself, purely for convenience since the original PSUs of my modules are from Japan so they need a 100VAC input and I live in a 220V country, so it's much simpler to use the small modern brick instead of adding another step down transformer to the mix.
