Unfortunately I'm missing some pages for this model, which include the jumpers information, but I managed to find it on the Packard Bell archive (https://archive.org/details/packard-bell-ftp-zd.-7z).
Jumpers
Main Board
J101 On* Colour Video Card
Off Monochrome Video Card
J102 On Bypass Keylock
Off* Keylock Enabled
J103 On Asynchronous Coprocessor Clock
Off* Synchronous Coprocessor Clock
J104 1-2 Expansion Bus Clock is the System Clock
2-3* Expansion Bus Clock is 8MHz
J105 Off* Write precompensation 125 nanoseconds
On Write precompensation 187 nanoseconds
J106 On Floppy Drive Speed is 250 / 500 kb/s
Off* Floppy Drive Speed is 250 / 300 / 500 kb/s
J107 On Interrupt IRQ12
Off* No Auxiliary Interrupt
J108 1-2* Coprocessor Clock is 32MHz
2-3 Coprocessor Clock derived from J111
J109 On* Cache SNOOPRDY connected to IOCHRDY
Off Cache SNOOPRDY not connected to IOCHRDY
J110 1-2* Diagnostic LEDs show Boot diagnostics
2-3 Diagnostic LEDs show ROM checkpoints
J111 1-2 CPU Clock is 32MHz
2-3* CPU Clock is 40MHz
J112 Off* 1 Speed motor on Floppy Drive
On 2 speed motor on Floppy Drive
J113 Off Floppy Drive Disabled
On* Floppy Drive Enabled
J114 Off Hard Drive Disabled
On* Hard Drive Enabled
The following jumpers have been added to main board PN 240-7835-3x
(circuit board artwork #85-3797-01)
J301 On Lock Pin Connected
*Off Lock Pin Not Connected
J302 On Monitor Mode Disabled
*Off Monitor Mode Enabled
J303 1-2 I/O Channel Ready Extended
*2-3 I/O Channel Ready Normal
* = Factory Setting
NB: J104 and J111 interact.
When J104 is at position 1-2, J111 should remain in position 2-3.
When J104 is at position 2-3, set J111 to position 1-2.
Memory
2Mb SIMM supplied as standard, expandable to 8Mb on the system board. The 7Mb of main RAM can be configured as either EMS or extended memory, in 1Mb blocks, upto a maximum of 7Mb's. The 224K of memory left in high memory can also be configured as either EMS or extended. SIMMs must be fitted in pairs, each pair of sockets making a Bank. Main Board Memory options are:-
Main Board Bank Bank Bank Bank
Memory 0 1 2 3
1Mb 256K 256K
2Mb 256K 256K 256K 256K
2Mb 1M
3Mb 256K 256K 1M
4Mb 1M 1M
5Mb 256K 256K 1M 1M
6Mb 1M 1M 1M
8Mb 1M 1M 1M 1M
