Reply 1060 of 1558, by demiurge
I got a Sparkle ECO Arc A310 and couldn't get it working on any of my retro PCs. I think it has to do with needing EFI boot.
I have a unique daily driver machine that has three VMs running off a single board so it is quite a pain to take down the host, install the card, configure passthrough, and reboot just to see if the card was RMA-worthy. Turns out the card is fine.
I will run the Kubuntu VM with this card and see if they are any better than the proprietary drivers I had to use with the previous 1030 which has less than 50% performance anyway.
