Reply 60 of 73, by Cursed Derp
- Oldbie
Gmlb256 wrote on 2024-07-05, 14:36:CONFIG.SYS: […]
Cursed Derp wrote on 2024-07-05, 13:26:Can I see what a proper config.sys or autoexex would look like for my situation?
CONFIG.SYS:
[COMMON]DOS=HIGH,UMB,NOAUTOFILESHIGH=30BUFFERSHIGH=10STACKS=9,256FCBSHIGH=4,0LASTDRIVEHIGH=H[menu]menuitem=EMC, Expanded memory + Mouse + CD-ROMmenuitem=XMC, Extended memory + Mouse + CD-ROMmenuitem=CMC, Conventional Memory only + Mouse + CD-ROMmenuitem=EM, Expanded memory + Mousemenuitem=XM, Extended memory + Mousemenuitem=CM, Conventional memory only + Mousemenuitem=WIN, Windows 98menudefault=EMC,10[EMC]INCLUDE=EMDEVICEHIGH=C:\DRIVERS\VIDECDD.SYS /D:MSCD0001[XMC]INCLUDE=XMDEVICE=C:\DRIVERS\VIDECDD.SYS /D:MSCD0001[CMC]INCLUDE=CMDEVICE=C:\DRIVERS\VIDECDD.SYS /D:MSCD0001[EM]DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFFDEVICE=C:\WINDOWS\EMM386.EXE I=B000-B7FF HIGHSCAN RAMDEVICEHIGH=C:\WINDOWS\SETVER.EXE[XM]DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFFDEVICE=C:\WINDOWS\SETVER.EXE[CM]DEVICE=C:\WINDOWS\SETVER.EXE[WIN]DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFFDEVICE=C:\WINDOWS\IFSHLP.SYSDEVICE=C:\WINDOWS\SETVER.EXEAUTOEXEC.BAT:
@ECHO OFFSET TMP=C:\WINDOWS\TEMPSET TEMP=C:\WINDOWS\TEMPSET PROMPT=$p$gSET winbootdir=C:\WINDOWSSET PATH=C:\WINDOWS;C:\WINDOWS\COMMANDSET SBPCI=C:\PROGRA~1\CREATIVE\AUDIO\DOSDRVSET BLASTER=A220 I7 D1 H7 P330 T6IF "%CONFIG%"=="WIN" GOTO WINC:\DOSDRV\SBLOADC:\DOSDRV\SBINIT.COMGOTO %CONFIG%:EMCLH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:MSCD0001 /EGOTO EM:XMC:CMCC:\WINDOWS\COMMAND\MSCDEX.EXE /D:MSCD0001:EM:XMIF NOT "%CONFIG%"=="CMC" C:\WINDOWS\SMARTDRV.EXE /X:CMREM CuteMouse doesn't need LH as it gets loaded into UMB automaticallyC:\DRIVERS\CTMOUSE.EXE /R2GOTO DONE:WINC:\WINDOWS\WIN.COM:DONEI reduced the number of BUFFERS to make disk caching utilities more effective and added an option to start Windows 98. 😀
Note that I don't know if there are any ROM chips in regions that could be used for UMB and the EMS page frame.
CHAAAAAAAAD
That's awesome bro!
I'll try that out a bit later
I am as smooth as a gravy train with flaming biscuit wheels.
