Reply 1060 of 1129, by marcushg85
MadLynx wrote on 2024-06-22, 10:45:marcushg85 wrote on 2024-06-22, 10:20:Hi and thanks to all who are contributing to this project. I've been following it for some time and after receiving some 89c52 chips I flashed the modded firmware bin 413 patch 5 and installed them (without a socket) on two 2290 cards I had. Can't make any of both cards to work now! Sbcheck doesn't detect them and diagnose gives some error.. any ideas? Both cards behave just the same.
I'm using them in a k6-3+ 600mhz on mvp3 boardIf the chips came from China than you should've double check if they flashed correctly. Chinese sellers OFTEN sell you scrapped ICs and there very likely be several bad blocks that can't be written.
Yes... they were recycled and came from China. Rewrote them a couple of times and also tried to erase them first. They both work and we're verified with no errors
EDIT: Desoldered the chips, verified them and flashed them again and resoldered them... Now both cards work! dsp 4.13 found
