Reply 53480 of 58183, by BitWrangler
Shponglefan wrote on 2024-07-06, 00:43:
The other case, I'm not sure yet. Maybe a Pentium III build? […]
I’m so jealous you can walk into a store and grab retro gear.
It's a numbers game. I've probably done between 5o to 100 visits to thrift stores this year alone.
Rarely is there any hardware worth getting, but once in awhile I get lucky. Mostly I'm just after old computer games.
I think I have one if not two of the "other" here but with a vertical slot silver grille bit. One came with a P4 in it, one was an XP/K7s5A I think, IDK long time back that one came in. Useable with care not super well vented for anything a bit furnacy, so maybe PIII is good.
Yeah the numbers game... I am hitting up yard sales tomorrow, upwards of 20 maybe due to two neighborhood sales, but it's a slim chance I'll even see anything. Generally though each Saturday pays off with some "new" shirts, or bits and pieces for the household, finally found a doorknob I needed to match a stripped out one (oldskool latch type) for an old door last week. So retro stuffs is icing on the cake really.
Reply 53481 of 58183, by AGP4LIfe?
Found this magnificently ugly beautiful beast at thrift center for 15$, CPU's included!! You think it will post?? 😁
The attachment PXL_20240707_014812951~3.jpg is no longer available
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 53482 of 58183, by BitWrangler
I'll cross some appendages for you, but it looks like it needs to be deep fried in deoxit or something.
Reply 53483 of 58183, by PcBytes
Except for quite a lot of grime on the board and ports, I don't see why wouldn't it POST for now.
You might want to look into a future recap though - I see Nichi HM/HN caps right smack from the bad batches, all crowded near the CPU sockets.
Reply 53484 of 58183, by BitWrangler
It looks just grimy until you get past the 4th PCI down and then there's some gnarly looking corrosion, like maybe the BIOS isn't making contact for one thing.
Reply 53485 of 58183, by dylanrush
Picked up this Osborne 1 from Craigslist today for a solid price ($100). By far the oldest in my collection now.
I have no software for it. I am thinking of either getting a set of Osborne software from eBay ($40) or buying a 5.25 drive for one of my other machines and making my own floppies for it. Or going with a GoTek floppy emulator. I am probably going to start by ordering the Osborne software, then see if the drives work, and maybe install the GoTek emulator later. What would you do?
Ultimately I plan on using this machine to SSH into my homelab server by way of Raspberry Pi and a serial connection.
The attachment 00X0X_f46U00wK9fk_0ww0m8_600x450.jpg is no longer available
The attachment 00N0N_1xWv9dUuYKA_0ww0oo_1200x900.jpg is no longer available
The attachment 00i0i_3hgH9yeH8zm_0ww0oo_1200x900.jpg is no longer available
Reply 53486 of 58183, by AGP4LIfe?
BitWrangler wrote on 2024-07-07, 03:15:
Hahah yea it is wicked nasty!, but I still think there's hope for a post . I'm gonna get after it tomorrow with a toothbrush and alcohol ect. 👍 I also don't have 2 socket 370 coolers 🙁
Reply 53487 of 58183, by AGP4LIfe?
PcBytes wrote on 2024-07-07, 03:11:
Surprisingly the caps all look pretty good, no bulging or leaking, considering the state of the rest of the board. Time to get out the multimeter!
Reply 53488 of 58183, by devius
AGP4LIfe? wrote on 2024-07-07, 06:04:
Socket A coolers also work if you have any of those.
Reply 53489 of 58183, by keropi
devius wrote on 2024-07-07, 09:49:
recently I was also looking for a decent S370 cooler and ofcourse I had some socket-a ones at hand
but I noticed that the retention clip of the athlon coolers is more rigid than the intel ones - it was made to apply more pressure on the cpu for better heat transfer
but AFAIR the socket-a athlon cpus had pads on their 4 corners to protect the die from cracking due to pressure / install of the heatsink
such pads do not exist (or needed) on the intel cpus
so maybe something to consider
Reply 53490 of 58183, by Trashbytes
keropi wrote on 2024-07-07, 09:53:
recently I was also looking for a decent S370 cooler and ofcourse I had some socket-a ones at hand but I noticed that the retent […]
I make shims from bits of dense foam for this, little square ones that I just stick to the substrate. They pretty much serve the same purpose as the ones on Athlon CPUs, dense foam is pretty easy to have at hand if you do any sort of shipping or store CPUs, but I guess some normal foam would work too.
I guess you could also use the 3M double sided sticky pads but only remove the backing from one side and just cut them to size.
Reply 53491 of 58183, by PcBytes
Recent car boot sale scores:
- ABIT NF7-S v2.0 - the RAID variant to my actual NF7 v2. Gets stuck on POST C1C0 regardless whether I have RAM installed or not. Any ideas?
- Luckystar 6BX2/P2 350 SL2S6/Intel 740 AGP/S3 soundcard (literally, the chip reads S3)/6.4GB WD Caviar -POSTs have not tested further
- Sapphire X1950 Pro PCI-E - untested, hope it works as I'd love doing a 478+PCI-E build with an ASRock P4Dual-915GL 😀
Reply 53492 of 58183, by to3cutter
First time owner of a SLOT A computer.
Reply 53493 of 58183, by AGP4LIfe?
Hmmm, I might have actually. Thanks for the tip!
Reply 53494 of 58183, by AGP4LIfe?
to3cutter wrote on 2024-07-07, 14:06:
Congratulations 🎉👏! looks fun!
Reply 53496 of 58183, by zuldan
AGP4LIfe? wrote on 2024-07-07, 01:53:
Did it post?
Reply 53497 of 58183, by AGP4LIfe?
zuldan wrote on 2024-07-07, 20:50:
Did it post?
Unfortunately no 😂, no beeps or anything. It does power on? And yes that pic is real LoL! To be fair I don't think I have the right/correct psu for the job. Nor did I test the CPU's individually, but even if they were bad I would get a beep I suppose. 🧐 🤔
Reply 53498 of 58183, by zuldan
AGP4LIfe? wrote on 2024-07-08, 00:17:
Did it post?
That's a shame. I don't suppose you have a post code analyzer card?
Reply 53499 of 58183, by AGP4LIfe?
zuldan wrote on 2024-07-08, 00:21:
Did it post?
** Update, Both CPU's Tested good in another machine**
I do not have any special diagnostic tools unfortunately. 🙁
