First post, by Rolling
- Newbie
I'm trying to resurrect an old Asus CUV4X board, which i found in the basement! 😁
Installed a Pentium III 866 MHz and 128MB SD RAM PC133 but it's stuck with post code C1, no beeps at all.
Without CPU installed, the diagnostics card gives FF, so i assume it's a RAM issue. I tried different slots, cleaned everything and measured the voltage on the ram slots (3.38v). I also tried different SD-RAM modules, but no success. It doesn't matter if a RAM module is plugged in or not, the error stays at C1.
Any hints would be appreciated 😀
