Bitchin' dual p-pro setup
Reply 80 of 90, by luckybob
I'm sure there is, I just haven't devoted any brain power to it. It feels like putting a semi diesel engine in a hatchback.
Reply 81 of 90, by H3nrik V!
luckybob wrote on 2022-01-28, 17:54:
depends on the board. CPU microcode is outside of my wheelhouse. As an example, it takes a bios update to run 900mhz P3 xeons. Without it, the boards cap @ 700 (or maybe 750)
The Xeons aren't locked downwards AFAIR, so they will most likely be at the highest the board knows?
Reply 82 of 90, by Sphere478
H3nrik V! wrote on 2022-01-28, 22:31:
Is there such a thing as a slot 1 to slot 2 adapter?
Sphere's PCB projects.
Reply 84 of 90, by hard1k
Hey luckybob, although it's not Christmas yet, but Santa has brought you a nice unexpected gift if you've been looking for the unobtainium SAC.EXE / IOPSETUP with the same poor results as myself!
ASUS P2B-D2 Driver CD (including the I2O Utilities!)
Check the \I2O folder, it's all there 😀 And yes, I've imaged that from an original CD that I got with the ASUS P2B-D2 board, lucky me! 😁
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 85 of 90, by M20master
These Asus p65upX boards are great! I own a 5. But I’m wondering what (kingston) ram I should use for it? What specs? EDO 60ms ECC 64mb? I would really want to have a total of 512mb.
Any advice of specific make/models where you have positive experience with?
Thanks!
Reply 86 of 90, by luckybob
Standard EDO ram. nothing special. 😀
ECC doesn't work on this chipset, if memory serves. So just get the cheapest 70ns ram you can find.
Reply 87 of 90, by M20master
Great, I’ll go and get that!
Thanks!
Reply 88 of 90, by M20master
Ohh and I want to buy your P65UP8! 😉
Reply 89 of 90, by luckybob
i'm going to be buried with it. ^.^
Reply 90 of 90, by M20master
I totally understand! 😂
