Pentium MMX DOS gaming build "Bright Star"
Reply 20 of 25, by OSkar000
Excellent build and modifications! Almost totally period correct and nicely done.
If one of my 486s had been a bit more tidy inside I would have done the same thing to it even though I'm not a big fan of windows on cases.
Reply 21 of 25, by WinSxS
momaka wrote on 2024-06-20, 23:17:
If that Enlight power supply is a legit Enlight unit, you're probably better off leaving it alone. Enlight usually built some pretty good PSUs back in the day.
Some Enlight PSUs (ATX) are related to well-known brand Chieftec - both were made by Sirtec.
b931f6304da3b8486e2ae4864680
Very similar stickers. It's not a coincidence 😀
Reply 22 of 25, by Tevian
🤣! This is a crazy build and I love it! Very much a through-back look. Very similar to my first PC case mod back in the day when I simply cut a large hole in the case side and bolted on some plexiglass just like that!
The multiple sound cards are interesting. Why not, right? I went a similar route but with multiple systems. Pentium + 486 in the same case just because I want to play some really old DOS games! MT-32 Pi is awesome also! I've only recently been playing with that.
Reply 23 of 25, by PcBytes
Spire on the other hand... well, as far as I recall, they didn't build *any* PSUs. They just slapped their label on various OEM and non-OEM vendors' units. While the quality of their CPU coolers was pretty good, their PSUs varied between OK/good and kinda-lame. IIRC, I saw at least one Spire PSU with Solytech/Deer/Allied internals (which is a so-so PSU manufacturer, though they do use cheapo quality electrolytic capacitors.)
I've opened a bunch of Spire units and so far none were Deer. The cheapest were Kissquiet and Yuelin, the mid range was iMicro (aka yx-gp), and the high end I'be had was Topower.
WinSxS wrote on 2024-07-19, 02:51:
Some Enlight PSUs (ATX) are related to well-known brand Chieftec - both were made by Sirtec. […]
Of note that not all Chieftecs used Sirtec. Most of their units were Delta\Newton Power, but not always, evidenced by your photo.
Reply 24 of 25, by BadBunnyHimself
Dude, that is an absolutely awesome build you have created there!
You have given me so many ideas that I want to try out in a new build of my own, I love how you mixed all the colours and tech in with an old retro system 😀
I normally just lurk around on this forum, reading all the interesting and useful things but I just had to create an account just to congratulate you 😁
Reply 25 of 25, by RetroPCCupboard
Amazing looking build. I am not offended by your choice to mod the case. It was tastefully done. Well done.
