Reply 27940 of 31007, by Demetrio
- Member
creepingnet wrote on 2024-07-17, 16:53:Demetrio wrote on 2024-07-17, 06:38:creepingnet wrote on 2024-07-17, 01:38:Installing a more *modern* O/S on my 486 DX4-100 Desktop....lol....burned some CD's, tried some stuff....this is what I Found... […]
Installing a more *modern* O/S on my 486 DX4-100 Desktop....🤣....burned some CD's, tried some stuff....this is what I Found....
- Damn Small Linux - not enough RAM (64MB)
- TinyCore Linux - not enough RAM (64MB)
- NetBSD - too big for a regular CD (746MB vs. 600ish MB)
- OpenBSD - Perfectumundo.......So, right now, she's installing OpenBSD over the internet and rocking it - full 80GB HDD with DDO, all packages, the works. I've been getting more into *.nix from a "user" standpoint in recent years so I think this might be a fun "revisit". I ran OpenBSD on a Pentium Pro 20 years ago and and screams. I'm nforget about it.
Ihe same from a 486, I'm kind of surprised I could find anything that can run at all. Planning to play around with it mostly, and see what I can do with it.If you install TinyCore Linux and its packages on the HDD, it will run with less than 64MB.
Problem is that booting the live CD requires 64MB, but you could try to do the installation on another PC and then moving the HDD to your 486DX
I have 64MB....might try that. This is my new "experiments" drive. I like doing batshit crazy stuff like this
Ah sorry, missed the (64MB) note 😄
Anyway, I managed to install TinyCore on a Pentium MMX with 64MB of RAM.
As you can see here, I'm able to do modern activities like surfing the Web in TLS and running the Python3 interpeter!
Had to find the correct installation steps to be able to install the system (no GUI) on the HDD, without incurring in Out-Of-Memory error.
I attached a txt file in this post: you might give it a try 🙂 (instructions are for a dual-boot installation with Win95, so you can just skip the steps for the latter)
