First post, by Ryune
I have Chewy ESC from F5 in bin/cue format.
I don't know how to play it. I managed to start few other games that are not bin/cue format. I have read the readme but I still can't to start the game. What I need to do?
Reply 1 of 17, by eL_PuSHeR
Well, I believe no one here has divination powers. What have you tried so far?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 17, by Ryune
I tried:
mount d e:\chewy -t cdrom
and it looks like it works.
Then
d:
d:setup.exe
and installer begins.
I choose install.
and it says I have not enough space on my disk ????
and also tryed to mount it like folder.
mount c c:\etc.
and then when I run installer and choose drive c which is only drive I am able to choose.
It says that it does not exist.
I don't know what else to try.
thanks for helping me out
Reply 3 of 17, by MiniMax
Rank Moderator
Moderator
60 Seconds Guide to DOSBox.
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 4 of 17, by Ryune
Well. I am confused.
This is the situation.
I have bin/cue files and I mounted them with dDaemon tool as drive G. Now The game is not installed. I cannot start the setup in windows cause it is DOS game.
On that link you posted how to start if you already have game folder but I don't have it.
So how am i gonna install it in DOSbox on my real drive?
Reply 5 of 17, by wd
Rank DOSBox Author
DOSBox Author
Create one?
Reply 6 of 17, by Ryune
How?
What I am gonna put in that folder?
I have only installation cd and i don't know how to install the game.
Reply 7 of 17, by wd
Rank DOSBox Author
DOSBox Author
How?
Presuming you're a windows user you could try it with the explorer.
Nothing.
Did you actually READ the posting that MiniMax told you? What about step 1?
Reply 8 of 17, by Ryune
I think I understand now.
I need to create empty folder and mount it as drive c and mount cd as drive d. and it will install the game on that empty folder. Am I right?
Reply 9 of 17, by Ryune
Thanks a lot people.
I got one more question.
What is about saving a game?
How ma I gonna load the game after saving?
Thank you very much
EDIT: And one more question, the last one.
Do I need to install the game again every time I want to play it?
Reply 10 of 17, by MiniMax
Rank Moderator
Moderator
Yep. And, since you already have a CUE-image, you can bypass Daemon Tools and mount the image directly in DOSBox:
mount D "P:\ath\to\where\your\image\is\filename.cue" -t iso
instead of
mount D "G:" -t cdrom
Edit: Yep = Yes.
_________________
Reply 11 of 17, by Ryune
Ok. but what you meant with yep?
I can't load game or what?
Reply 12 of 17, by Qbix
Rank DOSBox Author
DOSBox Author
why don't you try the suggestions and tell us the results ?
Water flows down the stream
Reply 13 of 17, by Ryune
Well, I said I started the game an it is working all fine.
I am aking what is about loading and saving? How do I load or save game?
I am sorry if I am boring. I really aprecciate your help. Thanks
Reply 14 of 17, by Qbix
Rank DOSBox Author
DOSBox Author
well you have to find that out yourself.
the game probably has a menu entry called save somewhere.
(try pressing escape or the F5 button(
Reply 15 of 17, by wd
Rank DOSBox Author
DOSBox Author
Please read the readme again, and check out your dosbox.conf
Reply 16 of 17, by MiniMax
Rank Moderator
Moderator
No, but many times it is necessary to mount the D-drive. Many games likes to check that the user has the CD, and is not running an illegal copy. So they check the D-drive for that.
Also, many games don't install everything onto the C-drive. Music, movies, and other stuff are often read from the D-drive.
Read the last part of my 60 seconds guide, where it says "If you have more than 60 seconds to spare....".
_________________
Reply 17 of 17, by Ryune
Thanks. It's all working now 😀
Thank you very much
