First post, by ziggy587
- Newbie
Sorry if this question has been asked before...
I have a motherboard that supports both 5v and 3.3v variants. Right now I have a 5v DX2-66 that I'm happy with. Would there be any worth in hunting down a 3.3v variant DX2-66?
I've recently watched a YouTube build video where the YouTuber noted that he had a 5v CPU and said "it would be a shame not to use a 3.3v CPU since the motherboard supports it" but didn't explain why that is. And I seem to recall reading random things here and there that would leave one to believe that 3.3v is better or more desirable in some way, but I've never read anything explaining specifically why that is.
I do seem to remember (but I cannot find the source now) reading that the lower voltage CPU will run cooler. And that seems more desirable for obvious reasons. But is it really? I mean, the 5v CPU was designed to run at 5v. And if the 3.3v CPU has lower power consumption, does that actually affect anything outside of my power bill? I couldn't find much in Google regarding this, maybe I'm not using the correct search terms. But if I plan on using a heatsink and fan either way, are there any real benefits to using the 3.3v over the 5v CPU?
