First post, by DaveDDS
Hi guys,
I've got an old Foxconn P4 mainboard that I've fairly recently set up
as a simple DOS system.
It has a network interface (RJ45) on the back panel, which appears to
internally be a SIS900 NIC.
This is what my PCINIC utility shows:
NIC#1 : Bus=0 Dev=4 Func=0
Vendor: 1039 'SIS'
Device: 0900 'SIS900' Rev:90
I/O: 0000E800
MEM: ED103000
IRQ: 0A (10)
I've got three slightly different SIS900 packet drivers:
SiS 900/7016 PCI Adapters Packet Driver Version 1.05 (04/16/99)
SIS900.EXE (22,947 bytes)
SiS 900/7016 PCI Adapters Packet Driver Version 1.13 (1/Aug/2001)
SIS900.EXE (29,125 bytes)
SiS 900/7016 PCI Adapters Packet Driver Version 1.15 (16/Aug/2002)
SIS900.COM (16,397 bytes)
All three "hang" when I try to run/install them - shows the startup
message, then no output and never terminates. (I've tried letting them
sit for several minutes)
If I disable the network adapter within BIOS, all three give:
Error: no adapter found with that configuration
(This is from the last one, it might be slightly different for
the other two, but essentially the same thing "No NIC found"
PCINIC also does not show it.
So, it looks to me like the NIC is there and being detected by the
packet driver - anyone use this NIC with a packet driver?
(Which driver are you using) - anyone have other ideas why it
hangs?
Btw, if I put a Realtek NE2000 compatible in a PCI slot, the NE2000
packet driver loads and works (so hopefully not something else wrong
with the system)
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filecopy(w/o netSW)via Lan/Lpt/Com
Reply 1 of 7, by tauro
Hello Dave,
Did you make sure that the NIC actually works correctly?
I had many motherboards from that era with on-board components that cease to work. Particularly NICs, sound cards.
An easy way to confirm that it works is booting BartPE or a GNU/Linux live distro.
Reply 2 of 7, by DaveDDS
tauro wrote on 2024-07-31, 03:50:
Hello Dave, […]
Hello Dave,
Thanks, I've not confirmed that the NIC actually works - not easy to put antoher OS on this system,
no cd/DVD, don't think this older MB supports boot flash...
Couple more bits of info - found and tried a SIS900 ODI driver (I can use PKTODI to make that work
as a packet driver) - almost but not quite the same result (hangs) .. the packet driver hangs but the
keyboard interrupt is still working as you can hit ctrl-alt-delete to reboot, but the ODI driver kills the
keyboard (prob. actually crashing) as you have to hard-reset.
Also tried a newer PCI Card (D-LINK 10/100 instead of the RealTek 10-only) - it has the
same issue (driver hangs) - so I'm now thinking maybe IRQ conflict or something like that)
going to fool around with manually configuring everything and see where it goes.
Really would like the on-board, as this is a "board mounter" system, and there are
no other cards. (Wouldn't hurt to have 100mbps either)
AFAIK the mainboard (with NIC) was working when I got it. When I build the DVD
Robot** I needed a crappy case to build it onto. A friend had just upgraded the oldest
machine in his lab (which was working) and gave me the whole thing. I only wanted
the case, so I tossed the MB in a box and just recently dug it out for a simple use..
** If anyone wants to see the "DVD Robot" :
"Daves Old Computers" -> "DVD Robot" (near bottom)
Reply 3 of 7, by DaveDDS
Weirdness - follow up - the on-board SIS900 NIC is working...
I'm not entirely sure why.
The PSU "somewhat failed" - the system would boot up but fail shortly after...
In testing, I happened to remove the hard drive - boot from floppy, and it worked
fine... More testing, the HD wasn't drawing too much power (but more than a 3.5"
floppy) and worked well in other systems...
I eventually took the board out and while testing on my bench it worked fine.
.. turns out the psu was failing and the one I use on the bench was fine...
ALso while on the bench, I happened to plug in a network cable, and tried loading
the packet driver - it worked and I could see the network!
-- and I also discovered that it the cable isn't plugged in the driver hangs
But... I'm not sure if I ever tried actually plugging in a network cable where
the system normally lives - I only had one there and it's used by another system.
so I might have just tried to see if one of several packet drivers I had for that
device would load... I don't know if the original problem was failing PSU/noise or
not having the cable connected...1
I do have one other system with a different NIC that also hangs if I try to load
the packet driver with no network cable ... so you'd think I might have thought
to test that...
But at least it's all working now and my "breadboard system" (no real case)
doesn't need cards in the open air anymore!
Reply 4 of 7, by dionb
One caveat with the SiS900 if trying to determine if it works in other OS: this NIC is supported by a default Windows XP install - but the default drivers have a bug: they read the wrong address to determine the NIC's MAC address, a location which contains non-unique code. Consequence is that every system with a SiS900 and default WinXP drivers will show up on a network with the same MAC, which can/will cause layer 2 havoc as soon as you have more than one.
Reply 5 of 7, by DaveDDS
dionb wrote on 2025-02-24, 12:15:
Interesting - I'm running DOS on this system, and I'm using a "packet
driver" (provided by SIS) - Hopefully it doesn't have the same problem.
I have three different ones, and the two most recent do work, but
the oldest one fails:
02-08-16 12:21p       16,397 D:\SIS900.COM
(c) Copyright 2002 SiS Corporation. All Rights Reserved.
Link Detected: 10Mb
PhysicalLayer Set: AUTO
Current Pmds: 0x00, num pmds: 0x01, hsm slot: 0x0004
Driver Installed at Interrupt 0x60, I/O address 0xE800, IRQ 11
Ethernet Address: 00:1C:25:37:FB:30
23-12-26 12:47p 29,125 D:\SIS900.EXE
(c) Copyright 2000 SiS Corporation. All Rights Reserved.
Link Detected: 10Mb
99-10-18 7:26p 22,947 D:\SIS900.EXE
(c) Copyright 1998 SiS Corporation. All Rights Reserved.
Error: can't initialize the hardware, errno = 7
The two that work do get the same MAC ... do you happen to know the MAC
address range that was assigned to SIS?
(or if anyone with a SIS900 can tell what it's MAC is - the first few
bytes should be the same)
Reply 6 of 7, by dionb
DaveDDS wrote on 2025-02-24, 18:46:
Interesting - I'm running DOS on this system, and I'm using a "packet driver" (provided by SIS) - Hopefully it doesn't have the […]
Link Detected: 10Mb
Link Detected: 10Mb
That's not the famous duplicate MAC with Windows XP, that is 00:E0:06:09:55:66
To check the vendor for a MAC address, enter the OUI (first six octets) of the MAC into a search engine like this: https://macvendors.com/
Your MACs that start with 00:1C:25 correspond to Hon Hai Precision Industries. That might not sound familiar, but it's the company Foxconn hardware is registered to, so that's exactly what you'd expect with a Foxconn NIC (or at least: NIC on a Foxconn motherboard). If the printouts with the same 00:1C:25:37:FB:30 MAC is from the same physical NIC, that's also correct.
Reply 7 of 7, by DaveDDS
dionb wrote on 2025-02-24, 22:53:
Thanks, useful to know.
Yes, the captures I quoted were from three different versions of the packet driver that I found while
initially trying to get the NIC working, but all were run on the same board/NIC (I would have been
concerned if they didn't get the same MAC - which is what I was testing for - I didn't know that the
wrong/duplicate MAC was known and sure to always be the same..
