Need quality VGA cable for 1600*1200 85Hz
First post, by shish_KEbOB
Hello, I have an IBM P260 crt screen I'm running at 1600*1200 85Hz but the image isn't perfectly sharp.
I can't use the DVI because my video card is limited to 60HZ on that output and the screen has no presets on 60Hz apart from 640*480.
I'm looking for a VGA cable that can handle such resolution perfectly, can anyone point me out one available in Europe?
I live in Italy so I can't order from monoprice (like another forum user suggested) without paying 30$ shipping on a 3$ cable.
Oh and I need the 9th pin. (or at least it seems like it from the manual).
Is there a recommended site for this that ships in Europe with decent fees?
What should I specifically look for to recognize a good cable?
Reply 3 of 15, by d1stortion
I guess it's not sharp because the closer you get to a CRT's limits, the blurrier the image becomes?
If you have a VGA cable with standard thickness (0.35" diameter I believe) and ferrite cores, not one of the thinner versions, this is probably about as good as it gets.
Reply 4 of 15, by shish_KEbOB
Nope no BNC, only DVI-I and d-sub.
I'm not 100% sure the video card is the problem with DVI, since reading other (more recent) card's manuals I don't see 1600*1200 @ 85Hz supported through DVI either.
I can see the pc detects the P260 if I connect a second screen, but I can't get it to display any image on it, no matter the resolution.
Shouldn't it simply revert to 1280*1024 instead of saying "no input"?
I would think the DVI port on the monitor is broken, but still the fact it gets detected seems weird.
Reply 6 of 15, by Logistics
Check the wire gauge on the jacket, does it say? IIRC, 24-gauge is common on svga cables, but I've found 22-gauge, before. Also, you can use a shorter cable. Professional monitors often came with 3-foot cables. Places like bluejeancable can custom make you a cable, too.
Reply 7 of 15, by obobskivich
+1 to being pretty close to the limit; IME on 19-22" monitors 1600x1200 and higher are usually only useful for video or graphics. Text and such is usually better served by 1280x960 (1280x1024 is not 4:3) or one of the "weird" tweener resolutions like 1440x1050.
As far as the DVI - it may be a digital connection, it may be an analog connection; what does the specific plug look like? See here for various examples of plugs: http://www.playtool.com/pages/dvicompat/dvi.html (there are CRTs throughout history that have both; some include the DAC to take DVI-D, some just take the analog component of DVI-I; if your computer's port is DVI-D only you cannot physically plug DVI-I/DVI-A into it (it's keyed to prevent this from happening)).
As far as hooking it up to a graphics card - a single-link connector will not do 85Hz, but dual-link DVI would be no problem, assuming it's actually a digital connection, and assuming the monitor can actually handle dual-link. What graphics card are you using? I know nVidia and ATi cards under their drivers can have "custom timings" setup which can help compatibility, if I remember right later 3DLabs, Matrox, and XGI cards can support this either through drivers, additional software from the manufacturer, or third party applications (like rivatuner); I don't know about S3, 3dfx, etc.
EDIT:
If we're suspecting the cable is bad/causing problems, does moving it or re-routing it change anything?
Reply 8 of 15, by bestemor
Here ya go:
http://www.ebay.co.uk/itm/151054683345
"Overseas: Please email us for a quote (available on smaller items only.)"
They have a full set of 3x5 pins. Very thick suckers... (good shielding)
Normally any good cables omits the 'barrels'(ferrite beads?).
Reply 9 of 15, by shish_KEbOB
Card is a Gainward gtx560ti, both that and the screen have a DVI-I connector, I'm using a dual link DVI-I cable.
Card manual actually lists the pin-out only for the digital pins, but says the port is DVI-I.
Probably I have to find DVI-A cable, I'll mess around with the driver in the meanwhile.
The VGA cable I'm using now is actually the one that came with my lcd display ^^
It's better than the SVGA cable I specifically got for this monitor at the local store, probably just because it's shorter.
Doesn't seem to show wire gauge, I'll look better tomorrow with daylight.
Oh I use this for games 😀
Reply 11 of 15, by shish_KEbOB
NJRoadfan wrote:
Have you tried the resolutions via DVI to see if they work or not?
Yes, as I said I tried many different resolutions through DVI and none work.
I also tried making a custom resolution with reduced blanking interval, no go.
On a second thought, if 85hz requires a dual link, then DVI-A is probably useless.
bestemor wrote:
Awesome! Waiting for an answer. Btw isn't 3m a bit long? Or is it no problem for a CL3?
Reply 12 of 15, by Holering
Cheap way to get monster quality BNC. Use RG6 coaxial cable with f-type plugs. Most people in U.S. with cable television or broadband internet have a ton of these and usually for free or just pennies (look up coaxial cable). It's shielded (sometimes double or quad shielded) and really thick gauge; weather resistant if you find something greater than rg6. You have to buy two f-type to bnc couplers for each cable (female or male coupler depending on your setup; usually f-type coaxial uses male f-type on both ends); these range anywhere from, $0.50 to $1.00 a piece on ebay. Just make sure the cable isn't bent or knackered in any way; and you probably don't want one beyond 6 feet unless you want to fill your walls with BNC jacks haha. Don't bend them with force either. You'll have something like a $400.00+ cable set no joke (use f-type to bnc or phono jacks myself with RG6 for laserdisc players and audio stuff).
Reply 13 of 15, by Logistics
Honestly, when dealing with video signals that are hard to push, proper cable construction is going to be critical. You need a professional-grade cable that is tested and for SURE keeps the impedance at 75-Ohm. Otherwise you end up with signal loss which degrades the picture.
Reply 14 of 15, by biessea
shish_KEbOB wrote on 2014-04-26, 09:07:
Yes, as I said I tried many different resolutions through DVI and none work. […]
Old thread I see. Anyway I am having the same issue with my powerful p260 IBM.
If I connect the dvi-i cable and select second input, the monitor remain in stand by. I changed the cable with another DVI cable and the problem remains.
I don't know, it seems the second input is broken. Or this is what I thought until I read this italian user (like me) that have this problem.
Perhaps he found a solution? I wanted to see if the image will be better using the second input, anyway I found a nice thik VGA cable and the image is nice with 1600x1200@85hz!
Computer lover since 1992.
Love retro-computing, retro-gaming, high-end systems and all about computer-tech.
Love beer, too.
Reply 15 of 15, by Ryccardo
I've seen some Scart haters criticize it because, just by looking at a socket, you can't tell which features it supports, which IMO is a reasonable opinion even though it's much better than having to rip pins out of a cable to make it fit…
...and yep, same case, this monitor is DVI-A, just with a DVI-I socket because close to 0 commercial DVI-A cables exist→ https://www.manualslib.com/manual/557842/Ibm- … 60.html?page=12 😀
Arguably, the DVI-I cable should not exist:
as a digital cable it doesn't fit DVI-D sockets,
as an analog cable it's only better than using a VGA cable with 2 adapters (and almost always you have a VGA socket on at least one side),
and even if both source and monitor are dual mode there's only a single I2C bus, meaning only one EDID that's supposed to say if the monitor is analog or digital 😀
And yes, even if you had a real digital input, they can fail - ask my Fujitsu E19-5, which started more and more often "syncing" to completely random noise as video signal was applied, then completely stopped accepting DVI input… and to say I spent almost 20 € on a DVI-I cable I had to rip various pins out to make it fit 😁
