First post, by zuldan
Trying to fix the flashing screen (bottom half) problem in Keen 5 with this card.
I've tried the S3VBEFIX - PC\MS-DOS TSR fix for S3 VESA 2.0 video BIOS
I've also tried S3 VBE/Core 2.0 (v2.18) - https://ctrl-alt-rees.com/2020-12-06-s3-virge … -downloads.html
Haven't had any luck with either. Is there anything else I can try?
The attachment IMG_5847.JPG is no longer available
Reply 1 of 9, by Joseph_Joestar
zuldan wrote on 2024-08-04, 06:52:
I think it's just an issue with Diamond's cards. Gona has documented it on his website.
It's a shame really, because Diamond branded Virge cards tend to have great image quality. But on the plus side, I think it's mostly the Keen games that are affected.
My retro builds
Reply 2 of 9, by zuldan
Joseph_Joestar wrote on 2024-08-04, 07:57:
Thanks Joseph. I forgot about Gina’s website. I’ll just have to live with it. The card works extremely well with everything else I’ve thrown at it. Glad I found the 4MB version in an old PC 😉 Crazy prices on eBay for a 4MB ($200 plus).
Reply 3 of 9, by mkarcher
Did you try enabling the SVGA compatibility mode in Commander Keen? That setting enables a workaround that will slightly reduce performance, but avoids the most common incompatibility beteween SVGA cards and Commander Keen by not relying on the video memory to wrap around after 256K.
Reply 4 of 9, by maxtherabbit
mkarcher wrote on 2024-08-04, 10:43:
+1
This usually fixes those types of issues. If it doesn't there is always the K1n9_Duk3 patches. https://pckf.com/viewtopic.php?f=4&t=6192
Reply 5 of 9, by Horun
Interesting that all the Diamond Virge types have this issue but not the others. Wonder what did Diamond did to their bios that would cause it.
Reply 6 of 9, by mkarcher
Horun wrote on 2024-08-04, 16:36:
Probably the S3 Virge has a control bit that limits the addressable video memory to 256KB. Commander Keen requires that this limit is active in EGA graphics modes. It seems the Diamond BIOS does not enable the "256KB only" mode in standard EGA/VGA modes. If it is just a control bit that is not correctly set, it would be a simple fix. You might also just try the BIOS from a different S3 ViRGE DX card. These BIOSes are usually completely interchangable, as there is nearly no way to "customize" a ViRGE/DX PCI card. You might for example try the BIOS from a Hercules Termintor 3D/DX. That BIOS initializes the ViRGE/DX chip at a sensible clock of ~70MHz, whereas some cheap OEM ViRGE/DX cards use a generic ViRGE classic BIOS that initializes the core clock to 45MHz, which yields awful 3D performance unless you change the clock using some 3rd-party utility.
Reply 7 of 9, by Horun
mkarcher wrote on 2024-08-04, 19:27:
Thanks ! I was thinking one of the other bios would work fine. I have a Cardex Virge 4Mb and a Diamond Virge ST 3D 4Mb and think I will try a bios swap just for kicks if the EDO memory is same speeds...
Reply 8 of 9, by zuldan
I didn't try that. Didn't even know that option existed. I must be the biggest Keen noob. The card works perfectly now.
Really appreciate everyone else's response. I have a much better understanding now of why this issue occurs.
Reply 9 of 9, by mkarcher
zuldan wrote on 2024-08-05, 09:05:
No problem with being a noob. I'm glad I could help you.
