IBM-7024 PowerPc
First post, by MMG
Hello guys
I just got a IBM-7024 PowerPc from 1996-7(?),my knowledge about this type of PC's are not so...much...
When i powering up,its have an error code on the built in small display what show "FEB" error code.
I did some research,some source say its some kind of firmware or bios problem,need some Floppy with recovery image.
If this FEB mean this,where i get that type of recovery image for that IBM?
I tried search,but no luck at all.
If somebody know something about this beast,please help me 😀
Few images:
The attachment 449937843_1862242350944562_3422181353410915039_n.jpg is no longer available
The attachment 452039099_1062572988808053_2479162811102990094_n.jpg is no longer available
The attachment 452013859_1973697049743459_5423578755272279113_n.jpg is no longer available
The attachment 20240806_141502.jpg is no longer available
The attachment 20240806_134554.jpg is no longer available
Reply 1 of 7, by MMG
And some image from stuffs what had inside.
CPU card(not even know yet what is it..):
The attachment 20240806_150921.jpg is no longer available
The attachment cpu2.jpg is no longer available
Other cards:
The attachment cc.jpg is no longer available
Reply 2 of 7, by akimmet
You have an IBM RS/6000 series workstation. If you aren't already aware these machine are not in any way PC compatible.
While I have some experience with SGI and Sun workstations, I don't have much experience with these machines. Nor am I familiar with AIX, the UNIX operating system for these machines.
You are more likely to find useful help on other forums that specialize in UNIX workstations.
Reply 3 of 7, by VivienM
akimmet wrote on 2024-08-06, 15:31:
I know very little about the non-Apple side of PowerPC, but could you run NT for PPC on these? Or are these AIX-and-maybe-some-BSD/Linux distros only?
Reply 4 of 7, by akimmet
Some of these machines could run NT4, but supported configurations were fairly specific and limited.
Reply 5 of 7, by eisapc
As written before this is a Unix workstation intended to run AIX (IBMs flavour of Unix).
As it is PCI allready it might be possible to run some PPC Linux on it as well.
Documentation can be found here:
https://www.ibm.com/docs/en/power4?topic=syst … 000-7024-series
Reply 6 of 7, by hyoenmadan
These days people is getting NT4 for PPC to run even in Big Endian only machines who never ever were meant to run NT4 in the first place, as it is an Little Endian OS.
If it still uses the MPC-104 memory controller, maybe someday, someone can port the maciNTosh (ELF) loader and the HAL to your machine. The rest of the peripherals seems pretty standard at the day, and the NT4 disk had drivers for these.
Reply 7 of 7, by davidrg
akimmet wrote on 2024-08-06, 23:03:
The NT 4.0 HCL lists these as being compatible:
  • IBM RISC System/6000 7024 Model E20 Server 604/100
  • IBM RISC System/6000 7024 Model E30 Server 604/133
The pictured CPU card is a 133Mhz PowePC 604 so it may well be NT-compatible. Assuming the owner can get it to boot of course.
