Reply 1940 of 2663, by Spesek
Falcosoft wrote on 2024-08-05, 21:02:1. Thanks! 2. I do not mind but I'm not too much enthusiastic either. Personally I do not think that so many meta chunks are nec […]
Spesek wrote on 2024-08-05, 20:12:Hi Falco, Alright, I've changed it to "must not be taken into account". Also, I have an idea for new chunks (similar to WAV): IP […]
Falcosoft wrote on 2024-08-05, 19:44:Hi, Here is an example original rmi file from Microsoft. As you can see the padding byte is not included in the size of the 'dat […]
Here is an example original rmi file from Microsoft. As you can see the padding byte is not included in the size of the 'data' and 'INFO' -> 'ICOP' chunks.
I still do not think that the right size calculation of a chunk should be 'optional'.Hi Falco,
IPRD: Album title
IART: Artist (IENG could be the creator of the soundfont and IART could be the creator of the midi)
IGNR: Song's genre
IPIC: Album cover image (or any image). Only PNG or JPEG allowed and the chunk's data is the binary of the imageAll of these are optional, of course.
What do you think?1. Thanks!
2. I do not mind but I'm not too much enthusiastic either. Personally I do not think that so many meta chunks are necessary but of course they cannot hurt anything either.
Most likey FSMP will not support these extended chunks 😀
That's fine. But if you change your mind, have this for testing:
It has name, artist, album, copyright, creation date and an album cover. Spessa should read these fine (click the "toggle music mode" button to see)
I think that for now, these tags are enough. And also i've added that a RMI-compliant synth can ignore all INFO chunks except DBNK as it's necessary to play files correctly.
Let me know what you think!
@Edit:
Github wikis (which the RMID spec is hosted on) are not indexed by Google. For example googling "about RMIDI" or 'SpessaSynth RMIDI' doesn't lead to the page.
This greatly limits their reach. That's why it would be great if you hosted a copy (or a link) on falcosoft.hu, as your website shows up in google search. It would greatly help popularizing this format.
No pressure of course 😀
