TinyLlama 3
Reply 120 of 295, by Eivind
Update: I got the 3.1 boards in, they look very good.
Happy to report that both the USB and I2S mux chips seem to work perfectly fine. Haven't yet tried sending I2S from the RP2040 to the CM4, will do that next.
The new horizontal buttons are nice and clicky, and the internal CM4-to-Vortex USB 2.0 connection is fully functional.
Will also work on getting a complete Pi image set up with all necessary software, ready to be flashed.
The attachment IMG_1473.jpeg is no longer available
The attachment IMG_1474.jpeg is no longer available
The attachment IMG_1476.jpeg is no longer available
The attachment IMG_1477.jpeg is no longer available
TinyLlama 3
ITX-Llama motherboard
TinyLlama SBC
Reply 121 of 295, by Duffman
Found some mini-pcie graphics cards.
https://www.digikey.com/en/products/detail/ve … PEE-V5E/4895622
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 123 of 295, by vutt
Eivind what's your recommendation on CM4 RAM/eMMC spec? Price difference is double between CM4 lite 1GB RAM/no eMMC and full tilt 4GB/32GB eMMC
Reply 124 of 295, by Eivind
vutt wrote on 2024-08-10, 09:21:
I went with the lowest eMMC+wifi board myself. 1GB of RAM is plenty, and if I need more storage I can always set up a shared network storage drive from another computer. Nothing wrong with shelling out a bit more if you want larger on-board storage, though.
Note that you do need the eMMC variant (as is written on the PCB itself), since there isn't room to fit a microSD slot for the Pi. Also, you'd be crazy not to have wifi - would be a nightmare to interact with the Pi without it. 😀
TinyLlama 3
TinyLlama SBC
Reply 125 of 295, by Eivind
Vridek wrote on 2024-08-10, 09:15:
Duffman wrote on 2024-08-10, 05:45:
I don't understand why these graphics cards are so terribly expensive.
Yeah, $260 is a bit on the expensive side for a SM750-based card. I think you should be able to get these for around $150 if you look around.
The reason they're so expensive is probably that they're made in quite small quantities and mainly sold as industrial equipment to companies to whom a couple of hundred bucks is a drop in the bucket. 😉
TinyLlama 3
TinyLlama SBC
Reply 126 of 295, by vutt
Note to myself - RTFM written on PCB 😀
Purist with FAT16 for DOS as I am 16GB with 7 partitions should be enough...
Reply 127 of 295, by Eivind
vutt wrote on 2024-08-10, 09:51:
We were talking about the CM4's storage, though? The TinyLlama itself has a MicroSD card slot you can populate with whatever size card you want - that's gonna be the main hard drive in DOS.
TinyLlama 3
TinyLlama SBC
Reply 128 of 295, by vutt
So operating system is running on TinyLlama SDCard and eMMC storage is used for whatever device CM4 is emulating. Ordered today 1GB RAM/8GB eMMC version.
What's your current estimate? When do you expect current HW iteration ready for us to use?
Reply 129 of 295, by Eivind
vutt wrote on 2024-08-10, 14:37:
Correct, the eMMC storage is primarily used for the Raspberry Pi's operating system, plus whatever else you want to serve to the TinyLlama over USB or serial.
Hardware revision 3.1 is done - as in, I've gotten a batch of boards that I'm currently testing. It all seems to work fine, so I guess I could put it up on github soon.
I definitely need to document a whole bunch of stuff, though. But yeah, in a few days maybe?
I already have 4 3 boards in hand and I suppose I'll order a few more if anyone's interested and don't want to do the whole PCB/assembly dance themselves. I'll get back to this later.
TinyLlama 3
TinyLlama SBC
Reply 130 of 295, by Eivind
I found out that the JST SH ("qwiic") connector was wired up the wrong way (thanks, Ahmad!).
I'll make another revision of the board to fix this - will also try to get ethernet wired up between the SOM and CM4, though this isn't trivial as the signalling levels differ (1.8v vs 3.3v) and the PHYs might be picky about the diff pair impedance, common mode rejection, etc. We'll see if I can find room on the board for some magnetics (transformers) and extra caps and resistors...
TinyLlama 3
TinyLlama SBC
Reply 131 of 295, by Eivind
Update: Just put in the order for a batch of revision 3.2 boards.
Changes from 3.1:
- Added an ethernet connection between the SOM and CM4.
- Added a third UART connection between the SOM and CM4 (mostly for control communication).
- Fixed the wiring issue with the JST connector.
- Improved shielding around the CM4's wifi antenna, to try to reduce noise when operating in 2.4 GHz (b/g) mode.
- Used the epoxy-filled/capped via option at JLC, to improve silkscreen asthetics (not visible in the renders below).
I'm working on an all-in-one program/script/service running on the CM4 that handles selecting/setting up floppy/cdrom images, synths, modem, etc - and can be controlled (over the new UART) from the SOM/DOS side using a utility program.
The attachment tinyllama3.2_render1.png is no longer available
The attachment tinyllama3.2_render2.png is no longer available
TinyLlama 3
TinyLlama SBC
Reply 132 of 295, by ahmadexp
Amazing, well done. Cannot wait for it.
Reply 133 of 295, by vutt
Amazing indeed. My CM4 arrived, so I have all the pieces now for final assembly.
Reply 134 of 295, by Eivind
A quick sneak peak at the control program I mentioned earlier:
The attachment IMG_1486.jpeg is no longer available
TinyLlama 3
TinyLlama SBC
Reply 135 of 295, by poprhythm
I've been away since V2 but this looks like excellent development, very excited! Here's an ANSI graphic I put together for kind of a boot screen in DOS. I'd be happy to share it if you'd like to use it.
The attachment Screenshot from 2024-08-23 11-12-30.png is no longer available
Reply 136 of 295, by ahmadexp
Just wondering, Eivind, have you ever looked into making Tiny Llama based on the som304rd52vine1 https://icop-shop.com/product/som304rd52vine1/?
som304rd52vine1 and cm4 will make the magic team. thoughts?
Reply 137 of 295, by Vridek
ahmadexp wrote on 2024-08-30, 03:33:
Now speaking for myself, apart from the price of the SOM which is really high this is a dead end, the IDE problem is really annoying.
Reply 138 of 295, by Eivind
Vridek wrote on 2024-08-30, 08:19:
I won't be trying to make anything with those DX-based modules anytime soon. My main reason is that I can't run my custom Coreboot/SeaBIOS ROMs on them.
I'm still waiting to hear back from DMP about their upcoming EX3 SOM though... That will probably be a much better fit for me, fingers crossed.
TinyLlama 3
TinyLlama SBC
Reply 139 of 295, by Eivind
Update: got the revision 3.2 boards in - and ethernet works! 😁
Still have lots of testing to do, but this is starting to look very good.
Pinging google from DOS (sorry for the lousy photo):
The attachment IMG_1497.jpeg is no longer available
TinyLlama 3
TinyLlama SBC
